A/D converters
Hello, Please can you advise if I can use these A/D converter chips to interface to any of the sharp Ir sensors GD2P12 - 120 range and also the Parallax PIR sensor. As I will be using up to 8 sensors I would like to know which will be best suited for the job. I realize that MAX1270 12-bit A\D has 8 inputs but it may not be the best chip to use.
www.parallax.com/detail.asp?product_id=604-00027
www.parallax.com/detail.asp?product_id=604-00026
www.parallax.com/detail.asp?product_id=604-00001
www.parallax.com/detail.asp?product_id=ADC0831
Never give up when things go wrong.
Post Edited (LILDI) : 8/23/2007 6:06:36 AM GMT
My 12 bit ADC's had problems with holding an exact number and that number would float up and down. So I had to use wider range of results from the ADC, before I would make a single increment change to my servos. When I do use 12 bit adc's, I trim them down to at least 10 bits.
www.emesystems.com/OL2tlc2543.htm
Tracy Allen
www.emesystems.com
Post Edited (StampNut2) : 8/27/2007 7:22:58 AM GMT
You can find very specific info about connecting the GP2xxx to the TLC2543 and the Stamp on Jonathan Peakall's page at...
madlabs.info/gp2d12/sharp_gp2d12.shtml
Tracy Allen
www.emesystems.com
