Math for triangulation of 3 radio signals
Does anyone know how to solve the mathematics to locate a point using trianglation of 3 radio signals on an uneven terrain?· I know how to do it on a flat plane but can't figure out on an uneven terrain.
in u still set a single plane that u know the elevation of the 3 rf ransmitters.
Then add or subtract the elevation of the bot to bring it to that set plane..
From that plane it's all geometry..
Bob N9LVU
A few bullet points:
1.· Distance between lost bot and 3 tri-bots will be less than 500' radius and elevation difference.
2.· The lost bot will transmit a data string consisting its ID, and an instruction for the 3 tri-bots to respond.
3.· The 3 tri-bots will then transmit a data string consisting of its known coordinates, and an acknologment bit and the ID of the lost bot.
4.· On a level plane, a distance of 500' (calculation of rf speed/time) would be 500'.· But if the lost bot is 50 feet above the 3 tri-bots at a distance of 50', the calculated distance would be 71'.· This is a big difference between 71' and 50', so the coordinates would be off by as much....
Any suggestions.....
- Stephen
I think you are going to need more than 3 points.· With only 3 points no matter where they are spatially you are going to form· a plane.· I think for proper 3-dimentional mapping you need·a total of 6 points.·
Beau Schwabe
IC Layout Engineer
Otherwise, I believe Beau is right, you don't have enough data in three points.
Truly Understand the Fundamentals and the Path will be so much easier...
and
Somehow you knew 71 was the hypotenuse of the triangle with legs of 50. Use trig to use the elevation angle and the measured "distance" to solve for the "vertical" leg of the triangle. Combine this with the established planar location (x-y) you already have worked out for the x-y-z coordinates.
Or, perhaps for a more rigorous approach, you might try this chain of articles (one leads to the next):
en.wikipedia.org/wiki/Surveying
en.wikipedia.org/wiki/Delaunay_Triangulation
local.wasp.uwa.edu.au/~pbourke/papers/triangulate/index.html
Or maybe you want to use a spherical approach--start at en.wikipedia.org/wiki/Spherical_trigonometry.
How accurate do you need to be (see introduction of article at www.movable-type.co.uk/scripts/gis-faq-5.1.html)? For example, in planetary exploration as described, is 1km or 100m close enough, or do you need 0.1mm? Are your sensor's and their mountings up to the required resolutions?
Finally, Johann Borenstein's "Where am I?" (www-personal.umich.edu/~johannb/) and related works should be of interest.
HTH,
Daniel
In our hypothetical situation, I know that #1 tri-bot is at elevation +10.· #2 tri-bot is at elevation +5.· And #3 tri-bot is at elevation +0.· Plug in any simulated time delayed distance (rf transmit/receive time calculation) and we won't know if the "lost" bot is +x or -x elevation.· Both + and - will be true, ah, just had a brain fart.· I could do the following:
With 2 tri-bots, there are 2 possible coordinates.· With 3 tri-bots, there is only one possible coordinate if all bots are on the same plane.· If the bots are·on different elevations, I will need more tri-bots to eliminate multiple true solutions to the equations, as noted by
My next problem is the exact equation and code for the program.
Is anyone up for a challenge of helping me write the program/s for this?· I am using a BS2 and the rf transmitter sold by Parallax (I'll get the model number later).· If it's ok with Parallax, I would like anyone who wishes to help, please contact me either here, or at my email.
- Stephen
Now I need to know the formula to use.· Something like side-side-side, or side-angle-side.· Anyone know what I'm trying to get at?
It's been a number of decades since I took my last class in trig, but as I remember, S-S-S can only be solved for special cases, namely right triangles, and equilateral triangles. Beware the dangers there, if that is indeed the case.
Bruce Bates
Perhaps I misunderstood earlier statements. I assumed that you would know the difference between a + and a - elevation (that is, you had both a distance measurement and an elevation measurement). I postulated that given the direction and elevation measurements of one object relative to another meant that one object could be chosen as the vertical ZERO reference (like the sea-level reference), and then all other objects could, from that reference plane, be positioned on the vertical axis.
BTW, is the "lost bot" a 4th bot?
Does your extraterrestrial planet(oid) have a large enough diameter with respect to the territory being explored that you can assume that the problem domain is flat?
Daniel
Very close to what I am thinking.· I do know the elevations of the tri-bots.· These will be established during the initial landing and set up of the first 3-6 tri-bots.· I thought about GPS, but Mars doesn't have the technology yet (maybe they do, but we don't know yet...he he he).· This leaves me with developing an rf location system.· Triangulation is the key, and my problem is how to solve the math.· I think I've figured it out, but my trig and geometry from my surveying years is rusty.
I've figured out that with 1 tri-bot, the signal will be anywhere on a sphere with a radius of x distance (x being the computation of send/receive time of the rf signal).· Adding a second tri-bot, we will have only 4 points at which the 2 spheres will intersect, regardless of the elevation of the 2 tri-bots.· The information about those 4 points when referenced to the 2 tri-bots will tell us the relative elevation of the "Lost Bot" (yes, the 4th robot).· The 3rd tri-bot will narrow down the location to 2 points.· And finally the 4th tri-bot will narrow it down to a coordinate and elevation.
The math is as follows, with a little rust thrown in:
Side 1 = Distance between Tri-bot 1 and Tri-bot 2. (constant)
Side 2 = RF distance calculation of Tri-bot 1. (variable)
Side 3 = RF distance calculation of Tri-bot 2. (variable)
I have to go to work, I'll get some pics uploaded later.
Won't the intersection of the surfaces of two spheres be a circle? (And the volume of the intersection of the two spheres something like a "flying saucer". [noparse][[/noparse]grin] )
Adding additional intersections quickly pares both the volume to more closely match the "point" location.
Don't forget to eventually account for the variability (error) of your measurements. Although I'd probably ignore the error in the initial mathematical solution.
Good exploring.
Daniel
you got three bots trying to find one bot in 3d space. If they were on the floor in the living room it would be 2d space.
Each locating bot need to be able to determine if the signal from the lost bot is below, equal, above the plane of your locating bot.
Do you have your locating bots capable of doing this function? and if so what resolution are you using, may I suggest you keep it simple with 8 points in each of the 3 axis. Including below. Your lost robot in the air will be able to find the 3 on the ground, without flying upside down.
or I guess you could keep sensors on sides and top of the bots and fly the incoming bot upside down.
Cyplesma, the lost bot is not flying, but if it is higher than another tri-bot, it will still send and receive the radio signal.· In a two plane system, living room floor, it would be easy.· But, we have to work on the 3d system.· I have the concept, see paragraph above, but can't remember how to use trig to calculate the coordinate and elevation.· I used to do it many years ago when I was in construction surveying, but I've forgotten many of the formulas.
Perhaps these trig identities ( en.wikipedia.org/wiki/Trig ) will help nudge the recollection. Don't neglect that little excursion through the history, and especially that interesting sketch from the 1728 Cylopedia (which reference covers spherical trigonometry in just over one column).
Daniel
keep in mind you surveying equipment you adjusted you beam in an up/down fashion and focused the lens for distance. (2 degrees of measure not just one)
by the way how many sensor points does each bot have?
Of course if you asking if any has any code or basic functions already written, I can't help with that, I'm just trying to help ya think it through.
If it was me, I'd make the sensor directional, do the transmit antenna omni directional, and make the receiving antenna directional. Even if the direction is controlled by either the bot's heading itself or by a motor turning the receiving antenna. break out excel and put the spreadsheet to use, that's how I usually do my math R&D.
Tri-bot 1 =· Northing- 1000'
················ Easting-··1000'
················ Elev.-········· 0'
Tri-bot 2 =· Northing- 1001.667'
················ Easting-· 1000'
················ Elev.-·······.42'
Tri-bot 3 =· Northing- 1000.833'
················ Easting-· 1001.667'
················ Elev.-······1.75'
Distance from············ to············· =
····· Tri-bot 1······ Lost Bot········ 12.5"
····· Tri-bot 2······ Lost Bot········ 14.5"
····· Tri-bot 3······ Lost Bot········ 17.5"
The elevation of the Lost Bot (as measured in this test) = .667'
In our solution, we can only use the tri-bot coordinates and the distances from.· The elevation of the lost bot will be a check to see if the formulas are correct.· Remember our tolerances are within an inch.
yeah or am I way off?
where the red lines intersect
I did do a landscape view to look at the bots from the side, bot all three circles intersect below the surface, which wouldn't be right anyway since the bots are not on the same plane.
!!maybe that's what you need to do determine the plane all three bots are on to find the angle to use to find the height.
I would have to imagine some earthquake locating trig would work here. Especially if that math works for locating an earthquake below the ground.
Post Edited (cyplesma) : 8/25/2007 11:19:59 PM GMT
Check other pages of the site if this doesn't suit you.
- Stephen
- Stephen
