BS2 Phone Line Interface and DTMF from Nuts and Volts 19
i was checking out http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv19.pdf·section on placing BS2 on phone line to dial.· in the schematic, it shows "280V Sidactor" from DigiKey (P3002AB-ND) but when i pull this item up on digikey it says "SIDACTOR 140V SURGE SUP M T0220"·
do you use two P3002AB-ND to get the 280V?
thanks!!
thanks!!
thanks for any input!!
Chris Savage
Parallax Tech Support
