Is Fullduplex serial usable this way?
Oldbitcollector (Jeff)
It is possible to employ 'fullduplexserial' in a way that would allow the prop to communicate in/out of the PC by way of the prop-plug interface after programming/startup? If so, where should I start on this?
Oldbitcollector
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Oldbitcollector
Paul Baker
I have a feeling everyone is missing the mark here. Could you describe your problem a little more fully?
Rich
