loss of power?
What would happen if an SX is cut off from vdd but not vss.· Would the pins got to ground, float, or would you have a·fried SX.· I do not have an SX, but I do have a pwmpal, which uses an SX.
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
No, when the camera shuts down the external 5v pin goes dead, my SX went dead, then the camera came back to life because its LanC pin was shorted to ground (this is expected behavior, but I didn't want it in my circuit, hence the transistor buffer).
