Wiring made eazy
firewater
I·just found this great web site that shows you how to wire microcontroller·projects using plain drawings to go along with the schemtics that can be hard for newbies like me to read.Quite a few projects and·code examples. They also have a software library their developing which is available for free while it's in the Beta phase.
"Wiring is an open source programming environment and electronics i/o board for exploring the electronic arts, tangible media, teaching and learning computer programming and prototyping with electronics. It illustrates the concept of programming with electronics and the physical realm of hardware control which are necessary to explore physical interaction design and tangible media aspects."
http://wiring.org.co/info.html
http://wiring.org.co/learning/index.html
A lot depends on your skills, your knowledge, and local resources.
In the beginning, we usually have little or no ablity to visualize or organize. So, it really helps to have a kit or a detailed presentation of how to do everything. But, once one has learned more, it gets much easier to be creative and not so reliant on mentoring.
Nuts and Volts is a wonderful example of a great place to get started. There are a lot of diverse projects and opinions.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
There's nothing like a new idea and a warm soldering iron.
