PDB pulse generator question
Hello.· I am trying to test my program which uses the COUNT instruction to count pulses on a pin.· I want to put some pulses on the pin, and I believe I could/should use the pulse generator on my professional development board.·
Trouble is, I don't know how to use the pulse generator.·
The PDB documentation for the pulse generator is very sketchy (well, actually it lacks a schematic), and it has only 3 short sentences on this feature.·
The PDB schematic doesn't help me much either.· I've read a lot of schematics before, but this one is confusing.· It has lots of pin connections at "GPIO" pins.· I guess GPIO means general purpose I/O, but I still don't know how to actually use it.·
All I want to know is how to use the pulse generator.· I assume it's already grounded on the board.· This seems like such a basic request.· Parallax obviously went through a bit of trouble putting the feature on the board.· Am I the only newbie who cannot figure this out?·
A simple paragraph indicating what we're basically doing, plus a good schematic, plus some sample code would be a GREAT benefit.
Please help.
Paul C
Please help.
Paul C
As this is a more advanced board there is less documentation/tutorials about it. The pulse generator is always sending out a pulse at the frequency listed below the LED lit up. By default at power up the pulse is 1 Hz (Square Wave). Each press of the button cycles through the frequencies (1 Hz, 10 Hz, 100 Hz, 1000 Hz/1 kHz). There really is nothing more to it. Those are the only frequencies you can get. Take care.
Chris Savage
Parallax Tech Support
paul
It seems like this is something that recently stopped working? It is hard to say what might be happening. To date I haven’t seen the pulse generator fail on any of these boards.
Chris Savage
The PDB documentation in the pulse generator area is very sketchy.· Do you have any more info.· It appears to use a processor IC to do it, and I was surprised it didn't just use a timer or similar (LM555).
Thanks.
Paul
There is no troubleshooting you can do, save testing the output frequency at each value. The reason for using the PIC instead of a 555 is that the PIC can handle changing the output by using a button press. This would be significantly more difficult to do with a 555 Timer. You can run a wire from the signal generator output into the audio amplifier input. When the pulse is on 1 you should hear a kind of tick from the speaker. When the setting is on 10 you should hear a rapid clicking. When it is on 100 you should hear a low tone and on 1000/1K you should hear a higher pitch tone. Take care.
Chris Savage
