a methode for steering servos and e-mots — Parallax Forums
nomadnomad Posts: 276
edited 2007-08-18 07:09 in Propeller 1
hi
here a little applications for steering
with the formula:
X = ((X * weight-1)+ Xf) / weight)
x = basevalue
xf = endvalue
if x < xf -> rampUp
if x > xf -> rampDown
weight: must greater as 1.0
if greater weights longer way to endpoint (smoother)
     Ramper_vers_10.spin
     for       : programm basics for ramping Servos Up/down
                 - from darwinWeights2.c
                 THIS PROGRAMM IS UNDER THE GNU-LICENCE
 *   This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
 *   Contributions:
 *                  parallax.com
 *                  http://www.parallax.com
 *                  Spieleprogrammierung M. DeLoran
 *                  page 145 ff. Mathematics
 *                  Author: John Olsen
                     engl. game programming gems, edited by mark deloura *==========================================================================*
CON
  _CLKMODE = XTAL1 + PLL16X     'Set to ext crystal, 16x PLL, 80MHz Clock
  _XINFREQ = 5_000_000          'Frequency on XIN pin is 5 MHz
VAR
  LONG Xnew        ' dynamic Value
  LONG Xold          ' "
  LONG X              ' servoValue
  LONG Xf             ' EndValue
                          ' if on 1.time Xf is greater as X then RampUp
                          ' if on 1.time Xf is smaller as X then RampDown
  LONG weight      ' dynamics greater smoother
  'intermediate results
  LONG w1, z1, z2, z3, z4, z5, z6
  ' value for abort repeat-loop
  LONG ab1, endval
  ' values for Float32-stuff from propNN2.spin
  long testerror
  long  vlong
  word  vword
  byte  vbyte
OBJ
  text : "vga_text"        ' create vgaText-object
  f    : "Float32Full"
  fp   : "FloatString"
PUB Main
  f.start
  text.start(16)
  text.str(string(13,"Ramper-Vers 0.10 VGA Output  ProtoBoard",13,13,$C,5,$C,1))
  rampUP
  waitcnt(96_000_000+cnt) ' wait only for looking the output of UP
  rampDown
PUB rampUp
  ab1    := 1.0
  weight := 30.0
  Xold := 90.0
  Xnew := Xold
  X      := 10.0
  Xf     := 100.0  ' EndPos only for graphic Screen y-pos is up
  endval := f.FSub(Xf,ab1)
  REPEAT                             ' originalformula: X := ((X * (weight-1.0)+Xf) / weight)
    w1 := f.FSub(weight,1.0)   ' w1 := weight-1.0
    z1 := f.FMul(X,w1)            ' z1 := X * w1
    z2 := f.FAdd(z1,Xf)           ' z2 := z1 + Xf
    z3 := f.FDiv(z2,weight)      ' z3 := z2 / weight
    X  := z3
    text.out($0D)   ' newline
    text.str(fp.FloatToString(X))  ' old without Float32Stuff -> text.dec(X)
    text.out($0D)  ' new line
    ' do something
    ' you can change X, Xf, weight dynamical
    IF X > endVal
      text.str(string(13,"Its UP and Quit",13,13,$C,5,$C,1))
      Xnew := X
      QUIT
PUB rampDown
  weight := 30.0
  X  := Xnew
  Xf := 10.0
  endval := f.FAdd(Xf,ab1)
    X  := z3
    ' do something
    IF X < endVal
      text.str(string(13,"Its Down and Quit",13,13,$C,5,$C,1))
      Xnew := X
      QUIT
it's all
regards
nomad
  • parskoparsko Posts: 501
    edited 2007-08-17 13:52
    Nomad,
    I'm pretty sure English is not your native language. You use "weight" where I think you want "wait". Not that this is a big deal, but it might confuse folks that think that your servo driver will use the "weight" of whatever you are controlling, confusing them. Please, this is not meant to be offensive. It's simply a bit confusing...
    Did you mean weight, as in mass? Or wait, as in time?
    -Parsko
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-08-17 14:16
    Parsko, 'weight' here means a numeric bias. Nomad has used it correctly.
  • nomadnomad Posts: 276
    edited 2007-08-18 06:45
    hi fred hawkins,
    you have the correct-answer
    regards
    nomad
  • deSilvadeSilva Posts: 2,967
    This is a program for numerically solving the differential equation
    dX/(xf-X) = dt/weight
    as can easily be seen by re-arranging Nomad's equation (Note: there is a typo in it, should read:
    X = (X * (weight-1)+ Xf) / weight )
    The solution is (simple calculus):
    -ln(xf-X) = t/weight + c
    X = xf - (xf-x0)*exp(-t/weight)
    (as the enclosed graphics also show)
    "weight" is a time scaling parameter, i.e. seconds, minutes, hours - or in other words: "how fast things are going"
    When you have no transcendent functions in your toolbox, numerical integration of the derivative might SOMETIMES
    come out faster than computing the formula itself... However not when using emulated floating point instructons smile.gif
    Edit: Well, had a lot of typos myself here...
    Post Edited (deSilva) : 8/18/2007 7:42:24 AM GMT
