Where to find pumps for Prop-controlled fountain
I've been thinking about building a fountain for my backyard. I started thinking today that it would be cool to make it a "dancing-water" type fountain. Basically a much smaller-scale version of this project. I figure I'll get four pumps and pulse them on and off with a Propeller and an RC-4.
Does anyone have experience with fountain pumps that they'd recommend (or stay away from)?
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
links:
My band's website
but I'm thinking you'd need a pretty fast pump to get pressure up high enough to jet water (how high?)!
I've been thinking of this too and am unsure how i want to tackled it. It would just be for a small backyard pond with a couple of water arcs passing back and forth.
I was thinking of doing it pneumatically. Have something similar to a bicycle pump, where you fill it with air and it pushes the rod out. The rod then forces water out of a nozzle/tube that sends a stream across the air. (do I then use a spring to bring the rod back to start position? or have a couple of valves on either side, and use air to force it back the other way creating another stream....
The downside would be a loud cranky pump, every once in a while, that would recharge the reserved tank of air....
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Tim
The STOP/START conditions that would be required for a pump to do what you are asking would be very hard on the pump and shorten the life of the pump. What you want to do is have a reservoir similar to what is often called a "water hammer", (only it would need to be bigger ) and "gate" the flow with a solenoid style valve rather than doing it from the pump.
Think of a large air-filled reservoir tank... as the "water pump" runs, the air inside the reservoir compresses increasing the internal reservoir pressure. ( Water pump stops when a set threshold pressure is reached ) A secondary line with a solenoid valve allows the resivor to bleed off the internal reservoir pressure in the form of short powerful controlled bursts. A secondary "air pump" may also be required to maintain an air cavity within the reservoir tank.
Beau Schwabe
IC Layout Engineer
Seriously, though, thanks for the info. You've saved me a lot of time and effort just to find out it wasn't going to work.
links:
My band's website
If you want a pump that could send a small diameter stream all the way·into your neighbors yard, LOL, try a gear pump instead.
links:
My band's website
Paul Baker
