SX Enigma...
Howdy...
It's been awhile since I played around with electronics.
Just moved into a new house and still unpacking...
However when I saw the Pocket Enigma by Dr. Jens Altenburg I wanted one too...
http://www.parallax.com/sx/sxcontest06/pocketenigma.asp
I managed to get the HPDL1414 from E-bay but the TSM7752B where no where in sight...
So it got replaced by one DLO7135 and one DLG7137.
Just plug it into a keyboard, input a key and type away.
The code is pretty much Jens code with a "few" modifications.
I could not get it compatible with my Enigma Simulator, so the encryption/decryption code was re-written.
I'm still working on the code, but it looks like I got the encryption/decryption to work with the
Enigma Simulator with it's default settings...
My Enigma Simulator,
http://users.telenet.be/d.rijmenants/en/enigmasim.htm
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
