Buffered TX and RX (SX/B + Assembly)
JonnyMac
My purpose in sharing this is two-fold:
1) I needed it; someone else may as well.
2) To demonstrate that with very little effort we mortals can take code from gurus like Guenter, Peter, etc., and fold it into our SX/B programs. Terry has done a great job constructing SX/B to allow the smooth incorporation of Assembly segments and I think this is a pretty good demonstration of that.
Notes:
-- TX and RX [noparse][[/noparse]circular] buffers are each eight bytes
-- TX and RX vars and code are independent of each other and can be pulled out and used separately
-- code prevents overrun of buffers when full
-- DELAY_MS used to replace PAUSE -- allows RX and TX while performing the delay
I've tested at the limits: 1200 and 38400 baud. Please let me know if you find any issues as this is getting folded into the latter chapters of my book. Thanks.
Notes:
When attempting to compile I got an error. See attached jpg screenshot.
You'll have to add a "RETURN __PARAM1" before the ENDFUNC to satisfy the compiler.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
Is that because the compiler expects the FUNC keyword to have an associated RETURN? I'm using 1.51.03 so I have not see the problem reported by T&E.
' ------------------------------------------------- ' Subroutine / Function Code ' ------------------------------------------------- ' Use: aByte = RX_BYTE ' -- returns "aByte" from 8-byte circular buffer ' -- will wait if buffer is presently empty ' -- rxBufCnt holds byte count of receive buffer (0 to 8) FUNC RX_BYTE ASM BANK rxSerial TEST rxBufCnt ' check buffer count JZ @RX_BYTE ' wait if empty MOV W, #rxBuf ' point to tail ADD W, rxTail MOV FSR, W MOV __PARAM1, IND ' get byte at tail INC rxTail ' update tail CLRB rxTail.3 ' keep 0 to 7 DEC rxBufCnt ' update buffer count BANK 0 ENDASM [b]RETURN __PARAM1[/b] ENDFUNC· Yes, it is expecting to see a RETURN somewhere within FUNC...ENDFUNC (I'll have to change the wording of the error message since it references ENDSUB which CAN be used without a return).
· It probably should be a warning instead of an error, since it doesn't prevent anything from compiling.
Bean.
Teacher: Correct !
