'Programming Failed' — Parallax Forums
Brian CarpenterBrian Carpenter Posts: 728
edited 2007-08-09 17:16 in General Discussion
I'm certain that this has been addressed before but in programming my SX28 i am getting a 'Programming Failed' message.· What does this mean.· is there any further explaination to help me pinpoint·the problem?
It's Only A Stupid Question If You Have Not Googled It First!!
    edited 2007-08-09 06:07
    I once got this error when I tried to program an SX28 with code for an SX48, i.e. code with a DEVICE SX48 directive. In this case, the IDE tries to write program data into memory areas that are not available on an SX28.
    Other than that, a damaged SX28 may also cause that error - did you try another chip?
    Greetings from Germany,
    G
  • BeanBean Posts: 8,129
    edited 2007-08-09 10:37
    MCLR not pulled up with a 10K.
    Not a full 5 volts at the programmer.
    Bean.
    Teacher: What is the difference between ignorance and apathy ?
    Student: I don't know and I don't care
    Teacher: Correct !
    www.hittconsulting.com
    Bean,
    thanks for adding these points - I simply forgot to mention them.
    G
