toString causing memory leaks!
Hey guys, I'm new to the Javelin and have been using it for a few months. As I've begun more serious testing of my work I discovered that the program halts at the same place after 10-20 minutes. Using the stamp.core.Memory.freeMemory() method suggested in one of the older posts I have worked my program down to the basics of:
while(true)
Clear_LCD();
free_memory = stamp.core.Memory.freeMemory();
LCDtx.sendString(Integer.toString(free_memory));
CPU.delay(10000);
Each iteration of this loop looses 16 bytes! I think the culprit is the Integer.toString(). Any suggestions or work arounds?
while(true)
Clear_LCD();
CPU.delay(10000);
StringBuffer buf = new StringBuffer();
while(true)
Clear_LCD();
buf.clear();
buf.append(free_memory);
LCDtx.sendString(buf);
CPU.delay(10000);
It is required that your LCDtx.sendString() method accepts a StringBuffer as parameter.
If it doesn't, you must make a method LCDtx.sendString(StringBuf s).
regards peter
public void lcdSendString(StringBuffer s) {
· int i=s.Length; int j=0;
· while (i > 0) {
··· LCDtx.sendByte(s.charAt(j));
··· j++;
··· i--;
and in your program use
lcdSendString(buf);
regards peter
for a StringBuffer s, s.toString() does not use any memory.
for an int i, Integer.toString(i) uses at least 16 bytes of memory every time it is called.
Therefore I have found a compromise between our two codes:
while(true)
Clear_LCD();
s.clear();
s.append("Memory: ");
s.append(free_memory);
LCDtx.sendString(s.toString());
CPU.delay(10000);
which does not result in memory loss. Thanks so much for your help, J
