Cool gadgets for the Hobbie robotics lab.
I'm in the middle of moving, and I have a whole new area to set up shop for my "lab" (unfinished basement). I thought this would be a good time to revamp some old equipment and perhaps invest some time/money into new equipment, to help make things easier or projects run smoother. Any one want to share their most use "gadgets" or projects that make things easier and better. for example,
I want to make a timing circuit for exposing photo resist PCBs, I currently just use a clock.
I've heard of soldering iron circuits that cut to 1/2 power if not used for a while.
some where on here I saw a triangle perf board used to measure wire so it fits is bread boards better.
I'm looking for ideas like this, what have you guys done?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
' {$STAMP BS2} ' {$PBASIC 2.5} This_Thread VAR Word My_Question VAR Word Your_Question VAR Word Cool_Thing VAR Word Abandoned VAR Word DO IF This_Thread = My_Question THEN DEBUG "Thank You For Your Time!" ELSEIF This_Thread = Your_Question THEN DEBUG "I Hope This Helps." ELSEIF This_Thread = Cool_Thing DEBUG "AWESOME!!" ELSE DEBUG "What Am I Supposed To Do?" ENDIF DEBUG "D Faust" LOOP UNTIL This_Thread = Abandoned·
You could use a Basic·Stamp and a DS1302 Time Chip from Parallax
·You could have the Basic Stamp Time turn··ON and OFF·the Exposing·Lamp or· Safe Light··for so many seconds or minutes· this timer could also be used··other timing needs for example time the Delovement of the board· after··Exposing it to light and so on you would just need some switchs for
different timers routines
Here is a Demo Code to get you started
http://forums.parallax.com/showthread.php?p=647603·Pool Pump Timer
http://forums.parallax.com/showthread.php?p=595469· Soldering Station Timer Controller
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/9/2007 3:15:48 AM GMT
as soon as the funds permit I want to get the USB O scope, and setup a permanent home for it on an a spare PC, with a custom housing.
I purchased a Drill press stand for a dermil, that makes a big difference for drilling PCB's,
I'm going to try and get organized enough to use the laser bin finder idea.
we'll I'm off to bed, thanks for the ideas.
