Passing a Hub variable down to cog?
I have an assembly routine running on a cog.
I would like a value in that routine to be updated by a variable stored in the 'hub' in Spin.
Is this possible?
I want to be able to change the variable in Spin (Increment from 0 to 255), and have the Hub its routine based on the change that was made in the SPIN.
Please let me know.
Shaun
Is this possible?
Please let me know.
Shaun
Sorry if that sounds confusing...but that is the only way I think I can describe it.
Is it possible to have 2 Parameters?
Shaun
to read the two parameters, you'd have the following code
entry mov ptr, par rdlong first, ptr add ptr, #4 rdlong second, ptr ... ptr long 0 first long 0 second long 0▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/7/2007 10:12:28 PM GMT
