SX/B SHIFTOUT - Multiple data in one command?
John Kauffman
Is there a way in SX/B to have SHIFTOUT send multiple values?
PBASIC has option for multiple [noparse][[/noparse]OutputData {\Bits}
SHIFTOUT Dpin, Cpin, Mode, [noparse][[/noparse]OutputData {\Bits} {,OutputData {\Bits}...}]
SX/B seems to not have that option
SHIFTOUT DPin, CPin, ShiftMode, Value {\Count} {, SpeedMult}
I searched Parallax site for SX/B “shiftout multiple values” and got no applicable results.
(The SX/B {\Count} provides for sending other then 8 bits, but that is not the question.)
Specifically, what is the best way to translate the following PBASIC to SX/B?
SHIFTOUT PinData, PinClock, LSBFIRST, Datum1, Datum2, Datum3, Datum4
Thanks.
Thanks.
This is similar to SEROUT in SX/B. Only one byte at a time.
The best way to handle this is to make a subroutine to do the SHIFTOUT. Then call the subroutine for each byte that needs sent.
Bean.
Teacher: What is the difference between ignorance and apathy ?
Student: I don't know and I don't care
Teacher: Correct !
www.hittconsulting.com
As Bean stated use subroutines like these for SEROUT but modify them for SHIFTOUT.
tmpB1 VAR Byte ' work variables tmpB2 VAR Byte tmpB3 VAR Byte tmpB4 VAR Byte tmpW1 VAR Word PROGRAM Start ' ----------------------------------------------- ' Subroutine Declarations ' ----------------------------------------------- TX_BYTE SUB 1, 2 ' transmit byte TX_STR SUB 2, 4 ' transmit string Cents_Char1 SUB 0 ' Custom LCD character 1 (Cents Symbol) ' ------------------------------------------------ ' Program Code ' ------------------------------------------------ Start: 'Initialize here HIGH TxPin PAUSE 100 Main: TX_STR LCD_CurOff TX_STR LCD_LightOn TX_STR LCD_CLS TX_STR " 50" Cents_Char1 TX_STR " Piece" TX_STR LCD_Cr TX_STR "Total = $" 'More code.... END ' --------------------------------------------------- ' Use: TX_BYTE theByte {, count} ' -- transmit "theByte" at "Baud19200" on "TxPin" ' -- optional "count" may be specified (must be > 0) SUB TX_BYTE tmpB1 = __PARAM1 ' save byte IF __PARAMCNT = 1 THEN ' if no count tmpB2 = 1 ' set to 1 ELSE ' otherwise tmpB2 = __PARAM2 ' get count IF tmpB2 = 0 THEN ' do not allow 0 tmpB2 = 1 ENDIF ENDIF DO WHILE tmpB2 > 0 ' loop through count SEROUT TxPin, Baud19200, tmpB1 ' send the byte DEC tmpB2 ' decrement count LOOP ENDSUB ' --------------------------------------------------- ' Use: TX_STR [noparse][[/noparse]string | label] {, count {, offset }} ' -- "string" is an embedded string constant ' -- "label" is DATA statement label for stored z-String ' -- "count" is number of characters to send (0 is entire string) ' -- "offset" is offset from head of string (0 is head) SUB TX_STR tmpW1 = __WPARAM12 ' get offset+base tmpB3 = 0 ' do whole string IF __PARAMCNT >= 3 THEN ' count specified? tmpB3 = __PARAM3 ' -- yes, get count ENDIF IF __PARAMCNT = 4 THEN ' offset specified? tmpW1 = tmpW1 + __PARAM4 ' -- yes, update it ENDIF DO READ tmpW1, tmpB4 ' read a character IF tmpB4 = 0 THEN EXIT ' if 0, string complete TX_BYTE tmpB4 ' send character DEC tmpB3 ' update count IF tmpB3 = 0 THEN EXIT ' terminate if done INC tmpW1 ' point to next character LOOP ENDSUB ' --------------------------------------------------- SUB Cents_Char1 TX_BYTE 249 ' define LCD Custom Character 1 TX_STR LCD_Cents ' LCD cents symbol TX_BYTE 1 ' display LCD Custom Character 1 ENDSUB '==================================================== ' User Data '==================================================== LCD_CLS: DATA 12,10, 0 LCD_Cr: DATA 13, 0 LCD_CurOff: Data 22, 0 LCD_LightOn: Data 17, 0 LCD_LightOff: Data 18, 0 LCD_Cents: DATA $04,$0E,$15,$14,$14,$15,$0E,$04, 0Post Edited (T&E Engineer) : 8/6/2007 11:37:09 AM GMT
But I'm having problems sending the contents of a byte size varible. What if you had these lines of code:
Price VAR byte
Price = 50
And you wanted to get the value in Price to show up on the LCD?
If I use: LCD_OUT 50 then I get the ASCII character #50 which is the numeral two.
If I use: LCD_OUT Price then I still get the numeral two.
In the end, I want the value of a byte size variable to show up on the screen as a number between 0 and 255. I think this would be a common need; your project senses or calculates a byte sized value and you want to use the LCD so the user can see that value
Thanks.
You may want to also take a look at this posting. Jon has code listed as SERIAL_LCD_DEMO.sxb and mine is LCD_Serial_RevE.sxb.
They show how to·display numbers 0-99 (or more) to the LCD.
http://forums.parallax.com/showthread.php?p=560786
·Bean also has a very good method that I am using in my current LCD project.
http://forums.parallax.com/showthread.php?p=603003
My project:
http://forums.parallax.com/showthread.php?p=660476
(code posted too).
Post Edited (T&E Engineer) : 8/7/2007 12:40:18 AM GMT
