Quick questions about SX KeyRing...
RobotWorkshop
Hello,
I just received my SX KeyRing this morning and had a few questions about it:
1 - It appears that the silkscreen is backwards where the SX-Key plugs in. I can follow the traces and used an ohm meter to confirm that I should not reference the silkscreen and the component side of the SX-Key should be up instead of what the silkscreen shows.
2 - The connector looks like it is center + and the outside GND. Can someone confirm the specs for the power adapter?
3 - Was there a datasheet online just for the SX KeyRing? There no longer seems to be any reference on the Parallax site for it.
Robert
Robert
1. You are absolutely correct.
2. Correct again. I use a 9-ish volt center positive wall wart. Works fine.
3. Can't help you here.
Cheers,
Peter (pjv)
