pullup/down or not at all
Guys:
i am working on a project that connects two bs2 stamps in series by one to· 5 pins
basically the last in line is sitting in loop scanning an input pin waiting for a high logic to come in, so that it can start its
routine.
the stamp connected to this pin is already doing its thing and sets and output to high when it wants the second bs2 to start or break out of its loop
my question is
when connecting two bs2's together do i really need pullup or pull down resistors? if so why?
thank you
bob g
routine.
my question is
thank you
bob g
Also, if the I/O pin is "drifting" and the voltage on the pin is near the switching threshold, the current consumption of the input circuitry will rise which is a problem if you're running things off batteries for extended periods of time.
