DC motor example
I can't find an example explaining how to connect a DC motor to the Javelin.
Does anyone know something about it? (except a motor controller)
Thanks a lot!
Thanks a lot!
Typically you’d use a Motor Controller such as the HB-25 or at minimum an H-Bridge to control the DC Motor. It really depends on what kind of control you’re looking for. Do you need speed control? Reverse capability?
Chris Savage
Parallax Tech Support
You could do that using just an H-Bridge or even using two Relays (One SPST and one DPDT). If you use relays be sure to drive them with a transistor. Take care.
Chris Savage
I need to control 4 DC motors, using the HB-25 it will cost $200.
Is it also possible using a PWM signal? (I see the PWMPAL can control 4 DC motors? or is that one-direction?)
Thanks!
Steve
It's a great controller, but I've got a motor that takes 7.2V and 200mA no load, 3.80A locked shaft.
This controller starts at 12V...
http://info.hobbyengineering.com/specs/SOLARBOTICS-KCMD-L298_Compact_motor_driver.pdf
See also this thread:
http://forums.parallax.com/showthread.php?p=573128
regards peter
does it still need extra components for speed control?
Edit: never mind, a PWM signal.
Post Edited (Robot Freak) : 8/18/2007 9:46:22 AM GMT
