d/a conversion
I need to produce reasonably precise voltages between 0 and, say, 5 volts to control an x-y recorder. Is it possible to use the BASIC Stamp to do this directly, or through a d/a converter chip?
You have pretty much answered your own query.· You want an external·D/A solution.· Now it comes down to how accurate you need to be.
You could use and R/2R Ladder with a voltage follower at the cost of a lot of I/O pins, or you could use a simple two wire (AKA I2C)·protocol·MAXIM part called MAX518.
http://www.ortodoxism.ro/datasheets/maxim/MAX517-MAX519.pdf
Me?· I'd go for using the MAX518 or something similar.· I've also been playing with real obscure parts like the I2C TDA8444· (No results to show for it yet)
Post Edited (pwillard) : 8/2/2007 8:35:20 PM GMT
You probably will need to use an external DAC. The Stamp can put out voltages from near zero volts to near Vdd (about 5V) to about 2 significant places using a resistor and capacitor.
Cyberpageman
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=14947
The DAC0808 is not quite as scarce as hen's teeth, as the trusty FindChips search engine
[noparse][[/noparse] http://www.findchips.com/ ] indicates there are at least 10 distributors who carry them, including Jameco.
Bruce Bates
What about the R2R method with a OPAMP follower.
Has worked for me on several occasions...
cheers
Ronald Nollet Australia
I looked up the DAC0808, and it seems like an elegant solution too.
I suppose I can use the STAMP to supply the binary input. I haven't had a chance to study how.
Tony Russell
http://forums.parallax.com/showthread.php?p=555268
http://forums.parallax.com/showthread.php?p=553090
Tracy Allen
www.emesystems.com
The MAX518 is a dual DAC with rail-to-rail 5V output·that uses I2C serial communication (IE; Data Pin & a Clock pin) so only 2 I/O pins on the stamp are needed.· Jon Williams did some excellent Nuts&Volts articles on using I2C style devices so you don't even have to re-invent the wheel on this one. Easily obtainable from DIGIKEY for about $6.00 each.
