CASE vs IF THEN statements
I have been tasked with writing code in pBASIC, which I am completely new to using. Infact, I haven't really programmed much of anything for a while. I could really use some help in understanding when a CASE statement would be better than an IF THEN statement. After pouring over the manuals, the two seem to be very similar, what am I missing? Any help and/or advice would be very much appreciated.
Good luck.
Another technique that I have to remind myself·to use,·is to spend some time analysing the distribution and span of the values in the set you are testing. Coders tend to be very linear thinkers (IF 1, IF 2, IF 3, etc). If the set of values you're testing is weighted toward "7" being more likely to accur than "1", you can change the order of you tests to optimize the speed of you tests. Likewise, knowing the span (range of deltas) in you data can help determine the granularity (steps)·of the tests that you have to make to optimize the speed. These techniques apply equally to a series of IF statements or a SELECT, CASE structure.
Cheers, Steve
Post Edited (Duffer) : 8/2/2007 9:35:26 PM GMT
NOTE: The BS2 through BS2pe do not have SELECT CASE implemented in firmware. To achieve a SELECT CASE, the command is translated by the PBASIC 2.5 Tokenizer into the following (The actual source isn't modified, however the result is effectively equal to the following translation in source code): EXAMPLE: TRANSLATES TO: SELECT expression IF expression condition1 THEN JumpLabel1 CASE condition1 : statement(s) GOTO SkipLabel1 CASE condition2, condition3 : statement(s) JumpLabel1: CASE condition4 TO condition5 : statement(s) statement(s) CASE ELSE : statement(s) GOTO ExitLabel ENDSELECT SkipLabel1: IF expression condition2 OR expression condition3 THEN JumpLabel2 GOTO SkipLabel2 JumpLabel2: statement(s) GOTO ExitLabel SkipLabel2: IF expression >= condition4 AND expression <= condition5 THEN JumpLabel3 GOTO SkipLabel3 JumpLabel3: statement(s) GOTO ExitLabel SkipLabel3: statement(s) ExitLabel: }▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Paul Baker
If space and pure speed are less of an issue, then whatever is most legible and makes the most sense to a human reader may be the best approach. When I'm writing first versions of code I often write using SELECT...CASEs or multiple IF...ELSEIF...THENs. When I'm sure my logic is correct and the code is bug-free, I convert all that kind of code to something like the sample below and it can free up a *lot* of space.
I would realy like for you or some one else to show this part in the
····································· IF THEN AND OR Statement
if you would not mind do this for me· and put the part that you are testing for in RED
I would like to THANK ANYONE that will take the time to explane it this way
In this example·that you have here·
What would this be in (IF THEN AND OR Statements )
(DEBUGIN·DEC·test
test·=·test//5··'pre·process·if·need·be·for·more·logic/error·checking
LOOKUP·test,·[noparse][[/noparse]·0,·0,·1,·3,·2,·1,·1,·3,·4,·1,·4,·4·],·idx···'lookup·test·and·choose·jump·label·--·allows·for·virtual·ANDs·and·ORs
'LOOKDOWN·test,·<=[noparse]/noparse][color=white]·[/color]$0,[color=white]·[/color]$10,[color=white]·[/color]$AAA,[color=white]·[/color]$F000,[color=white]·[/color]$FFFF[color=white]·[/color,·idx···'or·this,·or·both,·etc)
I·had a project awhile back where i had to many·IF THEN··Statements
This would realy help me understand better
·I have put this project on hold because
I·did not understand how to use this
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/3/2007 4:34:32 PM GMT
'the lookup versions... IF test = 0 OR test = 1 THEN 'do stuff "0" -- lookup would give idx = 0, the ON...GOTO label "0" ELSEIF test = 2 OR test = 5 OR test = 6 OR test = 9 THEN 'do stuff "1" -- lookup would give idx = 1, the ON...GOTO label "1" ELSEIF test = 3 or TEST = 7 THEN 'do stuff "3" -- lookup would give idx = 3, the ON...GOTO label"3" 'do stuff "2" -- cause it falls through in sample code 'do stuff "0" -- ditto ELSEIF test = 4 THEN 'do stuff "2" -- lookup would give idx = 2, the ON...GOTO label "2" 'do stuff "0" -- skps to 0 in sample ELESEIF test = 8 OR test = 9 OR test = 10 THEN 'do stuff "4" -- lookup would give idx = 4, the ON....GOTO label "4" ENDIFRemember that where you *do stuff "x"* above, could be a lot of code....
'the lookdown versions... IF test <= 0 THEN 'do stuff "0" -- lookdown would give idx = 0, the ON...GOTO label "0" ELSEIF test <= $10 THEN 'do stuff "1" ELSEIF test <= $AAA THEN 'do stuff "2" ELSEIF test <= $F000 THEN 'do stuff "3" ELSE 'do stuff "4" ENDIFOne of the nice things about lookdown/lookup in this context is that you can just easily choose to READ or I2CIN values for comparison (rather than a "hard-coded" list) which can make routines even more flexible.
Thank You so much for taking the time to·Explane this to me·this way I can understand very well
'the·lookdown·versions...
IF·test·<=·0·THEN
····'do·stuff·"0"·--·lookdown·would·give·idx·=·0,·the·ON...GOTO·label·"0"
ELSEIF·test·<=·$10·THEN
····'do·stuff·"1"
ELSEIF·test·<=·$AAA·THEN
····'do·stuff·"2"
ELSEIF·test·<=·$F000·THEN
····'do·stuff·"3"
ELSE
····'do·stuff·"4"
ENDIF
Can you Please explane this PART a little more in How each····· [noparse][[/noparse]#,#,#,#,#,#,#,#,#,#,#,#]·
and use this where each check would be······························ ·[noparse][[/noparse]A,B,C,D,E,F,G,H,I,J,K,L]
·What·is·this testing· [noparse][[/noparse]·0,·0,·1,·3,·2,·1,·1,·3,·4,·1,·4,·4·],·' I am a little Lost here can you explane this a little more Please
...............................A..B..C..D..E..F..G..H..I..J...K..L.......................................................................................................
'the·lookup·versions...
IF·test·=·0·OR·test·=·1·THEN
·············A··············C·························································· 'do·stuff·"0"·--·lookup·would·give·idx·=·0,·the·ON...GOTO·label·"0"
ELSEIF·test·=·2·OR·test·=·5·OR·test·=·6·OR·test·=·9·THEN
···················E··································································· ·'do·stuff·"1"·--·lookup·would·give·idx·=·1,·the·ON...GOTO·label·"1"
ELSEIF·test·=·3·or·TEST·=·7·THEN
···················D
········································· 'do·stuff··"3"·--·lookup·would·give·idx·=·3,·the·ON...GOTO·label"3"
··I am a little lost here............'do·stuff··"2"·--·cause·it·falls·through·in·sample·code
··........................................'do·stuff··"0"·--·ditto
ELSEIF·test·=·4·THEN
····'do·stuff·"2"·--·lookup·would·give·idx·=·2,·the·ON...GOTO·label·"2"
····'do·stuff·"0"·--·skps·to·0·in·sample
ELESEIF·test·=·8·OR·test·=·9·OR·test·=·10·THEN
····'do·stuff·"4"·--·lookup·would·give·idx·=·4,·the·ON....GOTO·label·"4"
ENDIF
··Thanks for any·
Sam
LOOKUP test, [noparse][[/noparse] 0, 0, 1, 3, 2, 1, 1, 3, 4, 1, 4, 4 ], idx 'lookup test and choose jump label -- allows for virtual ANDs and ORs
It works like this:
1. take the value of "test" and lookup the value in the list, starting with 0, based on test, put the value found in the list into idx.... so in the above, if test = 0, then lookup will find the 0th element in the list (the first element) and put the value found there into idx (in this case it is 0 by coincidence)
2. take the value of idx, which in looking at all the possible values in the list, will be from 0 to 4 ---
3. use idx to decide which label or subroutine to execute using ON...GOSUB.
Essentially you are "mapping" one set of values to another, with the "translated" values being integers from 0 to some number.
In the above:
test = 0 --> idx = 0
test = 1 --> idx = 0
test = 2 --> idx = 1
test = 3 --> idx = 3
test = 4 --> idx = 2
test = 5 --> idx = 1
test = 6 --> idx = 1
test = 7 --> idx = 3
test = 8 --> idx = 4
test = 9 --> idx = 1
test = 10 --> idx = 4
test = 11 --> idx = 4
If this doesn't make sense, it might be easier to try it on some real code. Write your code with IF...THEN and/or SELECT...CASE, then convert it (or post here). Logically there will be no difference, btw.
Thank You for your reply
Now I understand what you are talking about
This was the project that i put on hold because i did not understand how to use the lookup command
What i want to do is make a look up table that would do·the following
IF sun light·Hours =·9· ····and· 30 min··· then turn on relay for··7···· hours· And 30 min
·························· 10················································· ····7
·························· 10···········30········································6····················30
···························11···················································· ·6
···························11···········30······································· 5··················· 30
·························· 12.·················································· · 5
···························12···········30······································· 4··················· 30
·························· 13······················································4
···························13·········· 30······································· 3··················· 30
·························· 14····················································· 3
And do this with out having to have·10 ·IF THEN Statements
http://forums.parallax.com/showthread.php?p=601752
·Mike Green·had posted this to what i was asking but i did not understand all of what·he has here·so when i saw your post (Zoot)
I had trying the same thing i was hopeing that you would explane in more detail and you have and
I·want to Thank you for that i also want to Thank Mike Green·for his help in the past even if i do not always understand all of it
Mike Green
You can also use a lookup table with the READ and DATA statements. You could have a table with one entry for each number
of hours there's sun. The table entry would have the number of hours the lights need to be on. Since you seem to want this
in units of 1/2 hour, I'd make the table entries in terms of that. Here I assume there's never more than 19 hours of sunlight.
[color=blue]Table DATA 16, 16, 16, 16, 16, 16, 16, 16, 16, 16 ' Sun hours from 0 to 9 -> Half hours of on time DATA 14, 12, 10, 8, 7, 6, 5, 4, 3, 2 ' Sun hours from 10 to 19 -> Half hours of on time GetOnTime: READ Table+SunHours, HalfHoursOn [/color]This code fragment sets up a table in EEPROM with bytes containing the number of 1/2 hours the lights should remain on.
The offset in the table is the number of hours of sunlight seen [noparse][[/noparse]SunHours] (from 0 to 19). The result is put in "HalfHoursOn".
The two variables "SunHours" and "HalfHoursOn" can be bytes or nibbles if the values are constrained to be 0-15.
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/4/2007 11:51:19 PM GMT
I will post the code in half hour· Thanks
Here is the code that I some what wrote but it only has the hours not the 1/2 hours in it
When i frist wrote this code i test it with mins·not hours and seem to work alright but that as far as i got with it
and i want to learn more
Thank You for your· time that you are·give me so·I can learn this............................................
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/5/2007 1:25:40 AM GMT
Does this program work as you'd expect to, regardless of coding technique?
Probably should start a new thread on this...
One thing I'm not clear on -- you check the time from the RTC·to determine hour of the day to pick a timer, then REset the time on the RTC to 0, I presume to use it as a kind of stopwatch. Do I have that right?
Yes you have this right this because·I do not want have to reset the clock for day light saving or change the·ON and OFF·Time as the Season Change I want it to run by it self·NO·ADJ Need
What i had posted seem to work the way i was expect it to work but it was going to have to many IF THEN Statements
What should the heading be named so you which one it is
http://forums.parallax.com/showthread.php?p=666284
Thanks For all of·your Time And Help in this matter
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/8/2007 1:09:22 AM GMT
Could·you give me·an Example of how you would do this
I'm sure you could simplify all the TimerX...Y routines into a single routine with some parameters
Thank For· All Of Your Help
··Thanks for any·
Sam
