Running a long program and can't seem to get reading from a sensor continuously
project: Automated Pool cleaning system
info-
Using· :· LTC1298 A/D
Sensor: Ph sensor
When I run my Ph sensor program sperately from·A long program it works perfectly.
Problem: When I·include the·Ph sensor program into a larger program the values tend to freeze and not vary or just not show up at all.
What I want the result to be: I want the Ph sensor to continuously read and show me the values of the Ph level as it goes through the· larger program. Basically I want the Ph sensor to first take a reading go through the whole program and then take a second reading.
How the·larger program works: Based on the Ph level of the water·the filter will·turn on·and then the· Dispenser will turn on for a certain period of time and then turn·off at the same time the Depenser is on an·Alarm indicating that the Depenser is releasing a liquid into the water goes off. Then·the filter just keeps running for a certain period of time then stops and then the Water level sensor is turned on to·check if the water level is to low·and if it is then a water pump will turn on and run until the water level sensor incidates it's reached a certain level and turn off. Then that's the end of the program.
How I want the program to run:
1.) Take a reading of the pH level
2.) Turn on Filter
3.) Turn on and off Depenser at same time Turn on Water_Alarm
4.) Filter just keeps running for a certain time
5.) Filter Turns off
6.) Water_Level sensor turns on -checks water level if water needs to be added and if needed water pump turns on
7.) Take a reading of the pH level if level is normal then End of program otherwise it will repeat
Ph program by itself:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
CS····· CON·· 4······· ' Chip Select
DIO_10· CON·· 5······ ' Data I/O pin 10
CLK···· CON·· 6······ ' Clock
' LTC1298 configuration
AD····· VAR·· Word···· ' Variable to hold 12-bit AD result.
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
pH····· VAR·· Byte···· ' pH value of the water
HIGH CS··············· ' Deactivate ADC to begin.
HIGH DIO_10··········· ' Set data pin for first start bit.
again:
· GOSUB convert···················· ' Get data from ADC.
· GOSUB calc_volt
· DEBUG HOME, "A/D Reading: ",DEC AD,CLREOL,CR
· DEBUG "volt Reading: ",DEC v/100,".",DEC2 v,CLREOL,CR
· DEBUG· "pH Value is: ",DEC pH, ".",DEC2 pH, CR
· PAUSE 500······························· ' Wait a half second.
· GOSUB Filter
·GOTO again······························· ' Endless loop.
Filter:
IF pH > 7 THEN filter_on
IF pH < 8 THEN filter_off
RETURN
filter_off:
HIGH 7
LOW 8
DEBUG "power filter is off", CR
PAUSE 500
RETURN
filter_on:
LOW 7
HIGH 8
DEBUG "Power filter is on ", CR
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
config = config | %1011
· LOW CS·································· ' Activate the ADC.
· SHIFTOUT DIO_10,CLK,LSBFIRST,[noparse][[/noparse]config\4]· ' Send config bits.
· SHIFTIN DIO_10,CLK,MSBPOST,[noparse][[/noparse]AD\12]······ ' Get data bits.
· HIGH CS································· ' Deactivate the ADC.
RETURN···································· ' Return to program.
Whole Program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
cnt···· VAR Word
again:
· GOSUB calc_volt
· GOSUB Filter
Filter:
RETURN
filter_off:
HIGH 7
····································· <-- took out Fiter off command out
PAUSE 500
RETURN
filter_on:
LOW·7·········
HIGH 8
GOSUB Depenser
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
Depenser:
HIGH 11
PAUSE· 12000
GOSUB Water_Alarm
RETURN
Water_Alarm:
DEBUG BIN IN11
IF IN11=1 THEN FREQOUT 0, 1500, 2000
PAUSE 50
GoSUB Water_level
GOSUB off
RETURN
Water_Level:
LOW·8···· <-- put Filter off command here
DO
HIGH 9 ' Turn ON the 555.
COUNT 10, 133, cnt ' Count pulses.
' USE YOUR CONSTANT divided by 10.
LOW 9 ' Turn OFF the 555.
DEBUG DEC cnt, " umho", CR ' Display micromho.
IF cnt > 36 THEN LOW 3 ' Level too high, turn pump off.
IF cnt < 30 THEN HIGH 3 ' Level too low, turn pump on.
LOOP ' Do it again.
RETURN
off:································· <-- program turns off Water_Alarm once depsenser is off
LOW 11
IF IN11=0 THEN LOW 0
END
info-
Sensor: Ph sensor
2.) Turn on Filter
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
again:
· GOSUB calc_volt
· GOSUB Filter
Filter:
RETURN
filter_off:
HIGH 7
LOW 8
PAUSE 500
RETURN
filter_on:
LOW 7
HIGH 8
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
Whole Program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
cnt···· VAR Word
again:
· GOSUB calc_volt
· GOSUB Filter
Filter:
RETURN
filter_off:
HIGH 7
PAUSE 500
RETURN
filter_on:
LOW·7·········
HIGH 8
GOSUB Depenser
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
Depenser:
HIGH 11
PAUSE· 12000
GOSUB Water_Alarm
RETURN
Water_Alarm:
DEBUG BIN IN11
PAUSE 50
GoSUB Water_level
GOSUB off
RETURN
Water_Level:
DO
LOOP ' Do it again.
RETURN
LOW 11
END
- Stephen
There is no way to exit from the Water_Level routine, so it will loop endlessly there. You either need an IF ... GOTO, a DO ... UNTIL, or LOOP ... UNTIL, or some other branch statement to exit from that routine down to the return statement at the end of that subroutine.
Bruce Bates
Nope, that won't do it. It doesn't get past the LOOP statement. LOOP sends it back to the DO statement from which there is no escape!
Bruce Bates
