need reliable code for bs2 wth daventech srf-10 or srf-04
I have been working with the SRF-04 and now find that the SRF-10 is a better solution but my data is still a bit jumpy.·
I need to ping a room (around ten to 20 feet) set this value as the room size. ·The size of the room should then have 3 feet removed (for the·first 3 feet from the·wall with the sensor), the rest of the room is·divided into 5 separate zones. So from the sensor if the sonar reports the distance of 1ft or under then goto MOD8.· If the distance is 3 to 2 feet then goto MOD6.· If the distance is 3 to 2 feet and remains there for x amount of time then goto MOD7.· If the distance is equal to the range of the first zone after 3ft then goto MOD6.· If the distance is equal to the range of the·second zone after 3ft then goto MOD5.· If the distance is equal to the range of the·third zone after 3ft then goto MOD4·If the distance is equal to the range of the·fourth zone after 3ft then goto MOD3···if the distance is equal to the range of the·fifth zone after 3ft then goto MOD2.··If·the distance equals the room distance·then goto MOD1·and repeat pinging.·
The only other concern is that if the distance is reported to be right between·two zones, it will choose one over the other so as not to keep jumping back and forth.·
Anyone out there familiar with this kind of application.· I would sure appreciate a hand I have been at this for about 3 months with no real results.
Thanks! Daniel··
Thanks! Daniel··
Double posting messages makes it more difficult and confusing for everyone trying to assist you.
Although I don't quite understand what you're doing, here is one possible approach using the SELECT -- CASE command.
I'm SURE it will require modifications to have it work as you want it to.
'dist is in inches
Select dist
·Case <= 12
·GOTO Mod8
·Case 24 to 36
·For n = 1 to Some_Determinite_Time
·· IF dist < 24 OR dist > 36 GOTO MOD6
·NEXT
GOTO Mod7
Case = First_Z_Range - 3
·GOTO Mod6
Case = Second_Z_Range - 3
·GOTO Mod5
Case = Third_Z_Range - 3
·GOTO Mod4
Case = Fourth_Z_Range - 3
·GOTO Mod3
Case = Fifth_Z_Range - 3
·GOTO Mod2
Case = Room_Dist
·GOTO Mod1
Case ELSE
·DEBUG "No Range Case Match"
END SELECT
That should give you the basic idea (no pun intended).
Bruce Bates
Chris Savage
Parallax Tech Support
