Simultaneous multiple mechanical operations
hi,
i would like some clarification on this. is it possible to have multiple mechanical operations, motors, leds, etc, functioning all simultaneously with only one board? what i mean is that if a pin is programmed for a certain duration, that operation has to end in order to move onto the next one, no? so it's a linear process? or is there to order one's programming in a different way that one pin doesn't have to wait until the other pin finishes.
hope that makes sense...
Thanks!
Thanks!
- Stephen
Thanks in advance!
Post Edited (neosurreal) : 8/1/2007 5:20:28 AM GMT
- 2 motors (external I2C motor controller)
- 3 pan/tilt sensor turrets (Parallax Servo Controller)
- 2 PING sonar units
- 2 IR rangers (using external I2C ADC)
- 2 CDS light sensors (using external I2C ADC)
- LED "running" lights (using external I2C PWM out)
- 12x5 LED matrix display (using MAX 7221 display driver)
- 2 RC receiver channels
- misc. boolean sensors (low voltage, battery charger, etc.)
- DS1307 real-time clock (I2C)
- Emic text-to-speech
I set the code up so that it cycles through all the routines, but certain routines get run more often than others. In pseudo code it looks something like this:
START: ticks = ticks + 1 // 5 ' ticks count from 0 to 4, then repeat I2COUT to PWM LEDs ' run LED running lights every tick for smooth fades, etc SHIFTOUT to MAX7221 ' dump bitmaps, scrolling text, etc., every tick to LED matrix for smooth animation check boolean sensors 'simple check of input pins I2CIN once per minute from DS1307 or so to update real-time IF ticks = 0 THEN check RC X channel 'check each RC channel only once per 5 ticks because timeout on PULSIN is slow SEROUT to PSC 'run all the servos at beginning of the ticks cycle ENDIF IF ticks = 1 THEN check RC Y channel 'check each RC channel only once per 5 ticks because timeout on PULSIN is slow I2CIN from ADC for IR cliff/lowobj detector 'check twice per 5 ticks for faster stop at cliff/lowobject ENDIF IF ticks = 2 THEN check leftside PING 'check each sonar channel only once per 5 ticks because time can be pretty long I2CIN from ADC for rear IR detector 'check once per 5 ticks I2CIN from ADC for left light sensor ENDIF IF ticks = 3 THEN check rightside PING 'check each sonar channel only once per 5 ticks because time can be pretty long I2CIN from ADC for IR cliff/lowobj detector 'check twice per 5 ticks for faster stop at cliff/lowobject I2CIN from ADC for right light sensor ENDIF IF ticks = 4 do all the main parsing and behavioral code 'decide what to do based on sensors, etc SEROUT to Emic ENDIF IF ticks = 4 or MotorSpeed = STOP THEN 'motors are updated only once per cycle, or immediately if a stop command has been issued I2COUT to motor controller 'move the platform ENDIF GOTO Start 'do it all againOf course, it's all a bit more complex, and I set up my subsumption engine so that some sensors (like the RC receiver) are not checked when reacting to obstacles (this cuts the time through the loop to make reflex actions more responsive), but under ideal circumstances I'm getting 7-12 hz for the 5 tick cycle, which isn't bad for a Stamp (BS2p40). Again, none of this would be possible if I didn't have the "set it and forget it" advantage of the PSC handling servo pulses (though the serout overhead is a bit stiff) and the external I2C chip for PWM and ADC.
Post Edited (Zoot) : 8/1/2007 5:34:29 AM GMT
