PIR Sensor in Water(?)
Anyone know for sure if the PIR sensor will detect IR Changes in Water? I want to detect the movement of fish in a rather large aquarium and was thinking the PIR sensor might be able to detect fish swimming by (despite their cold blooded nature). I am planning to mount the sensor very close to the water's surface but am uncertain if this sensor would sense anything below the water surface.
Thanks for any advice..
-BigAL
-BigAL
The PIR Sensor detects rapid heat changes within its field of view. As fish are cold-blooded they will not create a heat differential that will be detected by the PIR, especially under water. You might try just an IR LED and Detector to detect momentary loss of signal.· Take care.
Chris Savage
Parallax Tech Support
You could try keeping a small whale or dolphin in your aquarium to see if that works with your PIR sensor. They're warm blooded.
All that aside, there's a good chance a LOT of the light will be deflected and refracted off the surface of the water. Most aquariums have a pump that intentionally breaks the water's surface to prevent a build up of that oily residue and aerate the water for the fish and bacteria. Your best bet is to put the sensor and LED on each side of the aquarium. This may not be what you need though.
If you want to detect movement, why not set up a grid like this:
+--------------------------------+ L | | S S | | L L | | S S | | L +--------------------------------+
Where L is a LED and S is a sensor. Make sure you cycle the LEDs and only active the sensor that corresponds to the correct LED. You can go real fancy and have an array on the other sides too. That would allow you to quite accurately determine position. Also keep in mind that the light may be diffused a LOT in your aquarium, depending on current, purity, air bubbles, etc, etc.
I am not an expert on fish-vision but make sure that a 38KHz (or thereabouts) modulated signal doesn't mess with their puny little brains. We've all seen what human science can do with sharks in Deep Blue Sea. Last thing we need is a super intelligent guppy ramming its way out of your aquarium.
An example of a BasicStamp2 powered guppy
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
Post Edited (Mightor) : 7/29/2007 6:01:05 AM GMT
Are you just trying to sense activity at one specific spot near the front of the tank? If so, I might have a different approach for you.
Bruce Bates
Gr,
Mightor
http://www.kenrinaldo.com/
His website menu system is a little different, this is how it worked on my computer:·Hover your mouse over the top-left pixel-flower until you see "art" and then choose the second single-square stem from the left for Augmented Fish Reality.
-Stephanie Lindsay
Gr,
Mightor
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
