newbie wants help with integer division — Parallax Forums
harry_sharry_s Posts: 7
edited 2007-08-01 07:58 in BASIC Stamp
Hi all
I am trying to experiment with PID...I am using an analog input of temperature spaning from 0 to 50C and I am using an ADO0831 with input span 0-5VOLTS.
I am calculating the temperature by
t= tempSpan * adcBits/255
I wanted to use the trick with the tenths of temperature that the stamp in class- industrial control uses but I get wrong results since I fail the result of the mutiplication is bigger than 64k...
how do I resolve this problem?
Can you please also recommend some source of information & tricks on how to do floating point calculations on basic stamp?
Thank you
  • BeanBean Posts: 8,129
    edited 2007-07-31 13:37
    I think the problem is that your input cannot be to the tenth of a degree (that would require an input value from 0 to 500).
    But you could get the temperature in 0.2 degree increments.
    Make tempSpan = 250 ' 50 / 0.2
    t = (tempSpan * adcBits) / 255
    tWhole = t / 5
    tFrac = t // 5
    Bean.
    Teacher: What is the difference between ignorance and apathy ?
    Student: I don't know and I don't care
    Teacher: Correct !
    www.hittconsulting.com
    edited 2007-07-31 13:44
    If you're interested, there's a discussion of multiple precision arithmetic with the Stamp including examples here under math: www.emesystems.com
    edited 2007-07-31 17:24
    Harry,
    You can probably use the */ operator. On your calculator find, multiiplier = tempSpan * 10. Then use,
    t = multiplier */ ADCbits
    That will not have the overflow limiitation and the result will come out directly in tenths.
    Edited: I had included a divide by 256 in the calculation of the multiplier. That is implied in the */ operator.
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 7/31/2007 9:18:16 PM GMT
  • harry_sharry_s Posts: 7
    Thank you all for your answers !!!
