12v to 5v converter?
hi all.
I have done some searching on this forum and have found nothing on the subject. so Im at your mercy..
I have this base http://www.lynxmotion.com/Category.aspx?CategoryID=57·and a·propeller with a bunch of sensors and stuff. ok now my question or need for input is for power. at first I thought I would want to run this whole thing from a 12 or 14v rechargable battery.· I was looking into a dcdc converter that would give me 12/14 volts in and 12/5/3.3 volts out.. but then I realized that i only really needed 5/3.3 volts out .. and then i got to thinking that I really only need 9volts out because the prop I have is the education board which has all the proper power convertion parts..
so my question is .. what do you think? I will have 12v coming from·2 6v Ni-HM 2800 mah battery packs.·can I power the education kit with this same battery..· or would you just use a 9v and to power sensors and prop, and use the larger battery just for motors?
another·option is to use the power lead from the center of the 2 6v batterys to power·the prop and sensors?
another option is to use a converter like I wrote about above.
opinions please?
thanks
IC layout designer
Austin Texas
opinions please?
thanks
IC layout designer
Austin Texas
D Faust
I'm under the impression that just putting in voltage regulators is not the most efficient way to drop the voltage, and results in excess heat. I'm less concerned about the 5/3/3 volts for the electronics, but am concerned about the current draw, and resulting heat loss from 18 high torque robot servos.
I'm not an EE, but have heard terms like DC/DC converters, switching power supplies, and others used in this type of application. What is the difference, where do we find these things, and how do we determine what is the best choice for a given application?
John R.
Click here to see my Nomad Build Log
http://www.dimensionengineering.com/switchingregulators.htm
IC layout designer
Austin Texas
@John R.: linear regulators act like automatically adjusting resistors. They automatically adjust to maintain the output voltage and waste any extra input voltage. Switching regulators are more akin to a lever or set of gears. They use active electronic circuits to trade voltage for current or current for voltage. This allows a switching regulator to operate at high efficiency even with a large difference in input and output voltage. This high efficiency is what makes them most suitable for use with heavy loads.
Good Luck,
Marty
Lunch cures all problems! have you had lunch?
