Prop as mouse
Hi,
I'd like to interface my 'custom made mouse'· to· a regular PC using the USB port.
The· 'custom made mouse' is another Propeller project I'm working on now (not finished), the details are irrelevant here.
What is important there will be 5 variables on the HUB : dx, dy,but1,but2,but3· holding intended change in X,Y directions, and bool values of the 3 buttons.
Those variables will be updated at ~20 Hz by one of the cogs.
I'd like to pass this 5 variables to a PC pretending it is some generic mouse and have a simple USB plug from the propeller to PC.
What would be the best solution?
I have read a bit about the USB interface and do not want to take the challenged of building full blown USB interface· from scratch.
Rather I'm considering a $5 solution:
- buy the simplest possible non-optical USB mouse (mechanical, with a ball rolling on the surface)
- connect· via 100 Ohm resistors 3 buttons to 3 Propeller pins to pass variables: but1,...but3
- mouse has a pair of photo-resistors· to· detect· the ball rotation in each direction.· I could· connect 2 LED (per direction) to the Propeller and sent 'dx'· pairs pulses to imitate movement of the mouse.
- change of relative phase between 2 LEDs· will be interpreted as direction (+ or -) of mouse movement
This is very clumsy, needs 7 pins, but should work w/ any PC w/o bothering to write a custom driver. And the total cost should be very low.·
What do you think?
Jan
What do you think?
Jan
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
No need for a scope to work out pulse frequencies you can get those from the ball/roller diameters and the number of slots in the wheels, not that you need to worry anyway as they will handle any pulse rates likely to be seen in mouse use, if your system is higher resolution you can add a divide ratio if you wish.
Graham
thanks for all advices.
this was simpler then expected.
Found some old mechanical PS2 mouse in·my basement and hookup 6 x100 Ohm resistors to
- L & R buttons
- 2x2 optical sensors output for X & Y wheels
To save Prop pins I used shift-out register SN54HC595, so only Prop 3 pins were needed. Pulses are injected in parallel to optical sensors outputs, at 1KHz.
The whole assemble is on the photo.
Attached movie demonstrates Prop calculating log(105) using calculator window. At first it clears old calculation,· enters the formula, at the end it kills the window.
Of course I have positioned the cursor at the '=' button by hand
Movie on YouTube :
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/I-jaSlxkdz4"> </param> <embed src="http://www.youtube.com/v/I-jaSlxkdz4" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Jan
Well done.
Graham
OK, i'll byte... How do you achieve the polling frequency with ball/roller diameters? Does this formula require magic smoke? lol
E3 = Thought
You don't need to adjust the propeller's code for maximum speed because the speed of the pulses should be goverened by the speed the custom made mouse is moved by the user.
If you did care about getting maximum speed you could always just keep cranking up the speed until it didn't work, that is no less scientific than using a scope to find out when it has stopped working.
Graham
Let me get this straight... you are emulating a mouse... with a propeller... hooked up to a mouse... to control a generic application on a PC?
This is better than "QuicKeys" www.quickkeys.com
Pure genius only comes in one form. Is this a project or a product?
Rich
Care to share the schemat and code?
If speed isn't a factor, as would be the case for handicap accessibility, then i'm sure this setup will work fine. This hack has potential though, in a syncronous config, you could interface the prop to a sensor like a gyro/accelerometer and with the addition of a few buttons you could use the interface as a controler for a game or two gyros for an FPS controller.
Hey, you know what Graham, whatever! I can see this turning into a peeing contest before long, you win. You wanna shoot down my ideas, go ahead.. but my mill is bigger!
E3 = Thought
Not knowing if he was a beginner or an expert I thought it was a good idea to let him know he could get his project working without a scope and without worrying about these details. It was about him not you.
I'm really not getting what this synchronous thing you are talking about is, there is the coms between the mouse and PC but that is most likely driven by the mouse movements rather than polled isn't it?
I don't know what shooting down someones ideas is, either something is correct or incorrect or I agree or I disagree, sometimes those two things don't tally (I get it wrong) but that's easy to fix through communication. If you think everything you write is sacred and should not be challenged then I suggest you write a blog and leave the forums to those with smaller but more capable mills [noparse]:)[/noparse]
Graham
Which is the goal of such a device ?
just googled a little bit about the PS/2 mouse protocol / mouse scancodes
that's what i found quickly
http://www.win.tue.nl/~aeb/linux/kbd/scancodes-13.html
http://www.computer-engineering.org/ps2mouse/
http://www.computer-engineering.org/ps2protocol/
greetings
Stefan
I'll share code & schematics in 1-2 days,
first come duties, fun is next - this is my toy
sorry
Jan
I got the code cleande up a bit. Below is schematics
to propeller │ │ │ │  │   ┌─────┼──┼──┼──┼──┳───────┐ Vcc│ SER │ CS │ 20kΩ │ │ A  GND  CLK │ free │ ┌┴──┴──┴──┴──┴──┴──┴──┴┐ │ │16 15 14 13 12 11 10 9│ │ ] SN54HC595 │ │ │1 2 3 4 5 6 7 8│ │ └┬──┬──┬──┬──┬──┬──┬──┬┘ │ B C D E F G H GND┐ │ │ │ │ │ │ │ │ │ │ 510Ω        │ │ │ │ │ │ │ │ │ │ │ M L R │ │ │ └───┐ │ │ buttons │ │ └─────┐│ │ │ │ │ ││ │ │ ┌────┼──┼───────┐││ │ │ │ ┻ ┻ │││ │ │ │ x1 x2 y1┣─┼┘│ │ │ PS2/USB │ rotation │ │ │ │ mechancl │ sensors y2┣─┼─┘ │ │ mouse │ │ │ │ │ USB gnd ┣───┘ │ │ +5V ┣─────┘ │ buttons │ │ L M R │ │ ┳ ┳ ┳ │ └───┴───┴───┴───┘The code: main and shift register 54HC595 object are attached as well as fiew photos.
Let me know if more details are needed.
The move showing demo in action is posted at youTube :
"http://www.youtube.com/v/Xiu2T4Z_ld8"
Jan
line one post one: "I'd like to interface my 'custom made mouse' to a regular PC using the USB port."
Propeller interfaces between a USB mouse and the custom made mouse.
Could you do without one and just use 7 lines instead of 4, or do you need it to get the outputs up to 5v?
Doug
of course.· I was only trying to save Prop pins. In fact I have tested the whole device using
7 pins and once it worked, I added the shift register.
It converts serial·· sequence· of 8 bits in to· 1 8-bit word· in its output parallel register.
So it ~10 x slower, but for human interface it is fine.
To test e.g. dx movement· you need just to pins connected (via 100 Ohm) resistor to 2 photo elements for the X-axis. Sent 00,01,11,10,00 and mouse will move by 1 or 2 pixels (for me it was always 2) - so do it on a loop, e.g. 20 times. You need to experiment with the speed, I'd start at 10 Hz --> 1kHz.
At a higher frequency cursor moves more pixels per cycle, reproducibility degrades, Y & X axis diverge.
For button pins it is simple hold 1 for push and 0· for release. For· some mouses the logic is reversed - I measured· logic first with the voltmeter.
And 3.3V from the Prop is fine - no need for 3.3 --> 5 V converter.
Good luck
Jan·
Sign me up.
can't post edit yet[noparse]:)[/noparse]
TABLE WAS SUPPOSED TO GO HERE
Post Edited (Fred Hawkins) : 8/5/2007 9:23:40 PM GMT
