Incandacent Bulb
I am making a circuit that uses a Solid State Relay that uses the PWM statement to control brightness of incandescent bulbs on the 110 line. I have my eyes on this relay www.mouser.com/search/refine.aspx?Ntt=653-G3E-220T-US12 for cost. The dimmer has 255 (1 byte) steps. What frequency does a filament best respond to?
PWM, rb, <what should the duration be?>
Or should I do something else?
I look at this relay data sheet it dose not say any thing about being able to use this in a dimming mode so i do not know
that you will be able to use it for what you want to with it
If i have time latter i will see if i can find something that might work for you
··Thanks for any·
Sam
You could do a little dimming by switching on the SSR for a variable number of half cycles in some period of time (like 1/10 second). It would give you a limited number of levels and the results wouldn't be anything like linear light levels, but it would be something.
The easiest way to dim an incandescent lamp with a PBASIC Stamp is to use the X-10 lamps modules and employ the PBASIC XOUT command. You can find documentation and examples of the XOUT command in the PBASIC Syntax and Reference Manual, or in the PBASIC Help File. It really couldn't be simpler.
Bruce Bates
Post Edited (Lightfoot) : 7/28/2007 8:46:38 PM GMT
You'd connect the logic output to an I/O pin. It would be delayed a little from the actual zero crossing because the LED has to have enough voltage to fire. You'll have to figure out that time delay and work it into your program if it's important.
2. Does the zero cross circuit trigger the microcontroller to run the pulse width modulatation code?
Post Edited (Lightfoot) : 7/29/2007 7:35:08 AM GMT
2) Yes, the zero crossing detector gives the starting time. Simply delay for whatever fraction of a half cycle you want, then trigger the triac.
Post Edited (JonnyMac) : 7/29/2007 2:06:16 PM GMT
Please let me know when these board are for sale because I want to buy one of them· FC-4 fader board········· Nice...
··Thanks for any·
Sam
FWIW, I've attached the FC-4 triac circuit schematic for your reference. The input to the MOC3023 is referenced from the zero-cross signal -- the longer the hold-off from ZC, the dimmer the lamp. The FC-4 uses an ISR that runs every 32.5 uS which gives 256 segments of each half cycle of the AC.
plp_a = 0 tris_a = %0001 ra = 0 DO DO UNTIL RA.0 = 1 'Zero cross is attached to RA.0, wait for it to fire. LOOP PWM RA.1, rb, 50 'Pulse width modulation value is read from RB port. LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Post Edited (Lightfoot) : 7/29/2007 10:42:40 PM GMT
' Dimmer service runs every 32.5 uS (256 accs x 120 Hz) ' -- inspired by code from Phil Short ' Dimmer_Service: ASM JNB ZCross, Update_Ch1 Zero_Cross: CLR Lamps ' all triacs off MOV acc1, level1 ' reset dimming accumulators MOV acc2, level2 MOV acc3, level3 MOV acc4, level4 Update_Ch1: IJNZ acc1, Update_Ch2 ' update timer SETB Lamp1 ' triac on when expired Update_Ch2: IJNZ acc2, Update_Ch3 SETB Lamp2 Update_Ch3: IJNZ acc3, Update_Ch4 SETB Lamp3 Update_Ch4: IJNZ acc4, Dimmer_Done SETB Lamp4 Dimmer_Done: ENDASMYou might be able to adapt this to high-level code like you're attempting, but you have to remember that when a triac is activated it can only be turned off by removing the gate and hitting zero-cross.
Post Edited (JonnyMac) : 7/29/2007 10:52:21 PM GMT
plp_a = 0 tris_a = %0001 'Triac is on pin RA.1, Zero cross detector is on RA.0. DO UNTIL RA.0 = 1 Wait until zero cross fires. LOOP DO RA.1 = 0 'Shut off triac. PAUSEUS RBC 'somewhere between 0us and 8333us, receive as a WORD. RBC represents the off time. RA.1 = 1 'Turn triac on. DO UNTIL RA.0 = 1 Wait until zero cross fires, triac will remain on until next zero cross. LOOP LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
An ISR is shorthand for Interrput Service Routine, a routine which is invoked whenever a (specified) interrupt occurs.
Bruce Bates
2. Johnny, is your interrupt triggered by the zero cross detector? If this is the case perhaps I can put this code in the interrupt code block.
Post Edited (Lightfoot) : 7/30/2007 8:47:45 AM GMT
You might try something like this:
Main: triac = IsOff IF ZC = 1 THEN acc = level ENDIF INC acc IF acc = 0 THEN triac = IsOn ENDIF PAUSUS 32.5 GOTO MainNote that when using constant values with PAUSEUS, fractions are allowed. You might want to use a 20 MHz resonator to give yourself plenty of resolution with PAUSEUS.
Post Edited (JonnyMac) : 7/30/2007 1:45:23 PM GMT
