Error reading from the serial port (timeout)
I have a Javalin Stamp on a USB BOE. After programing it with a small test program I tried a quick change and to reprogram it.
I get the following error:
"Error reading from the serial port (timeout)"
The IDE successfully finds the Javalin but programming doesn't work.
I have a LCD AppMod installed and it appears the IDE is successfully reseting the Javalin. The LCD display goes blank when the IDE says reseting. It doesn't display anything else until I hit the reset button and it displays the text from the last program I successfully downloaded.
Any suggestions?
Any suggestions?
http://forums.parallax.com/showthread.php?p=585022
Hit the program button as soon as possible after recycling power to the javelin,
to prevent the javelin from executing the current program.
regards peter
I thought that the Javalin was supposed to be compatible with all Parallax development boards.
This sounds like the Javalin should not be used on USB BOE boards.
Since I will not purchase another Parallax product given this problem it looks like I have a dead Javalin--since I have no way to reprogram it.
If I ever do get it reprogrammed--what constitutes a "very small" program?
We’re still working on the problem…It appears to related to timing issues (latency) inherent in the USB to Serial conversion. To some degree even BASIC Stamps are affected by this which is one reason why so many USB to Serial Adapters don’t work on the BASIC Stamp and we created our own. If you contact Tech Support Monday we’d be happy to have you return the Javelin and refund your money. I really hope this isolated issue does not cause you hesitation in buying from us in the future. We have found work-arounds which work quite well for other issues. This one is still being worked on. Take care.
Chris Savage
Parallax Tech Support
Discarding packet
and sometimes:
Discarding packet
Discarding packet
Possible Javelin on COM3 did not respond.
Unable to find a Javelin on any port.
i tried modifying the latency settings, installing new USB drivers, switching to a different machine, and using the PrimeJavelinEEPROM.bat program posted on other forum entries. Unfortunately, none of these work. Do I need to use switch to a serial board with USB converter cable? Is there something else I should do?
-josh
http://forums.parallax.com/showthread.php?p=656527
regards peter
