Help me select size and type of Chemtronics Solder-Wick desoldering wick
Friends:
Which Solder Wick size is the best to use for PCB's using .1" spacing? Is there some advantage to the version that contains flux?
Thanks amigos,
Migs
"Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs'
"If the doors of perception were cleansed every thing would appear to man as it is, infinite" - William Blake
"We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." Carlos Castaneda
"One single grateful thought raised to heaven is the most perfect prayer. " G. E. Lessing
“How much of human life is lost in waiting.” Ralph Waldo Emerson
"Men often mistake notoriety for fame, and would rather be remembered for their vices and follies than not be noticed at all.” Harry Truman
My website: www.intoku.net my e-mail:mreznicek@pretensa.com me:Miguel Reznicek
Post Edited (Migs) : 7/23/2007 8:56:46 PM GMT
Thanks amigos,
Migs
You really need flux to draw the solder into the wick, but you don't need to buy pre-fluxed braid. You can just dip the braid in some flux right before desoldering, or apply flux directly to the joint.
Having some separate flux around is useful for all sorts of situations and can sometimes be needed even with flux already on the wick.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
Yes, but which size do I choose in this brand? The numbers don't directly state the width of the wick. They are like A, B, C... so what I need is for someone who uses this wick to say "get size #2 as it will be the most useful all around".
Migs
