The pause works. I seems that when the program ends is when this problem happens. If I am going to keep something on, should I not let the program end?
Just as with the SLEEP command, pins will retain their input or output settings after the BASIC Stamp is deactivated by END. For example, if the BASIC Stamp is powering an LED when END executes, the LED will stay lit after END, but every 2.3 seconds, there will be a visible wink of the LED as the output pin switches to the input direction for 18 ms.
Update -- If you just want to turn the LED on and then leave it at that (and I won't ask why), then just lose END.
-Mega
Want to know how to build your own robot?
www.societyofrobots.com
Need good forums for things other than programming?
http://www.societyofrobots.com/robotforum/index.php
Post Edited (Megaman935) : 7/23/2007 3:26:32 PM GMT
' {$PBASIC 2.5}
DEBUG "Program running", CR
HIGH 8
END
-Mega
Post Edited (Megaman935) : 7/23/2007 3:26:25 PM GMT
-Mega
Post Edited (Megaman935) : 7/23/2007 3:26:17 PM GMT
-Mega
Post Edited (Megaman935) : 7/23/2007 3:26:10 PM GMT
You can also use the STOP command.
Bruce Bates
