Hyperterminal connection to BS2
I know there was a posting in 2004 about this, but for the life of me I can't get it to work.
I would like to send and receive data to the stamp via hyperterminal 5.1
When I open hyperterminal and set it up with 9600 8n1, the stamp goes into permanent reset mode.
I tested this by setting an led to go high on the first line of the program. Works with the debug window, but not with hyperterminal.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
To Newzed: Your program is still giving me the same issue.
To pwillard: I think you are on the right track. All the program is doing (for testing) is setting a pin high through to an led. The moment I open my hyperterminal session or Newzed's, the light goes off.
I am using windows xp, hyperterminal 5.1 and a usb (from PC) to db9 (to stamp) cable.
I have tried using another computer to make sure nothing fishy is going on with my computer, but I get the same result.
The hyperterminal program works fine with another device (microhard radio).
So how do I shut down the dtr pin (pin 4?) in hyperterminal? Is there a command I can send inside the window?
Thanks for the quick responses.
Nerdicus Maximus
Sid
Don't have VGA?
Newzed@aol.com
File, Properties --> Configure button
Post Edited (PJ Allen) : 7/19/2007 6:41:38 PM GMT
You can either disconnect this signal in the cable (as you seem to be doing) or the BOE has two capacitors which 'decouple' the DTR signal, so you only get a single 'reset' when it first goes high.
And yes, if you were programming your PC using Visual Basic, you could set "DTREnable = FALSE", and the DTR pin would not go high. Hyperterm is not that smart, even when you turn handshake off in Hyperterm. Been there, done that.
Post Edited (pwillard) : 7/20/2007 12:29:50 AM GMT
http://forums.parallax.com/showthread.php?p=640960
QuattroRS4
'Necessity is the mother of invention'
