Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Transistor — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Transistor
Kitman
7
2007-07-18 20:25
edited 2007-07-18 20:39
in
BASIC Stamp
Is there a different between PNP and NPN transistors? I am wondering if it would make a difference if you switched a PNP for a NPN in the circuit. All advice and insight welcome.
Martin Hebel
1,239
2007-07-18 20:39
Is there a difference? Very much so! NPN's require a more positive voltage on the base (The P in NPN).as compared to the emitter.
The PNP requires a more negative voltage on the base as compared to the emitter.
Here's some basic info:
http://www.kpsec.freeuk.com/components/tran.htm
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
Sign In
Register
to comment.
