RPM sensor for gas motor
Hi Guys
I would appreciate your help.
I'm trying to measure RPM off the plug lead of a gas (petrol) motor. The idea is to have a clip-on sensor that fits over a lead to one of the spark plugs and gives a suitable signal. Reliability is a bit important. Being able to fit and remove the device quickly and easily using unskilled people is very important hence the use of a plug lead sensor.
My searching has not turned up much (plenty on connecting to the low tension side or using "hall effect").
I found the following extract of a circuit that is used to trigger a car strobe light.·I'll obviously need to filter the spark "rebound".
QUESTION: -·Do any of you have a better circuit? If not, how·can I improve this one.
Kind regards from the bottom of the world
John Bond
Post Edited By Moderator (Bean (Hitt Consulting)) : 7/18/2007 12:26:13 PM GMT
John Bond
Update -- Careful around plug leads, when they get old and start to rot out, you could more than couple in the signal, you might draw an arc to your project.· So, better proximity than contact (IMHO.)
Post Edited (PJ Allen) : 7/18/2007 8:40:48 PM GMT
http://www.tinytach.com/tinytach/gasoline.php
You only have to wrap the pickup wire 3 times around the spark plug wire.
MikeS
Also I have seen several applications, including automotive OEM's that used PJ Allen's suggestion. Although the OEM's would normally rap a wire around a ferrite ring and run the plug wire through the ring.
If it is just a piece of equipment, "Tiny Tach" sells a combination tach and hr. meter that is self powered and uses the wire rapped around the plug wire for about $40.00.
Hey Capt Quirk, that "Application Notes" on hall effect is amazing. I've used them and known a fair amount about them but this level of detail...
Regards
John
