Voltage
Hey--
I'm trying to make some simple circuit things for a local rocket competition. Sorry if my question isn't worded clearly, this is my first time doing this sort of thing.
Anyways, I was wondering whether you guys knew whether/how I could amplify the output of a barometer so that i could get a clearer reading of the lower values? Say, increase the 2.5 V-4.3V range to 0-5V, since that's the range that my ADC can read? I've read about step up transformers, but that would just double or triple the voltage supply--2.5 would just become 5, I couldn't make it 0, right?
For a discussion of op-amps and their use, try the Wikipedia (Google "Wiki operational amplifier")
I agree with Mike Green's suggestion. However, there may be other ways to do it. Which ADC are you using? It may have built-in offset and gain controls. If it is an 8-bit ADC you could get a gain of 16 by going with a 12-bit ADC.
There has been a lot of discussion about altimeters on the Rocketry Forum. I did a search for the keyword "altimeter" and the reults are at www.rocketryforum.com/search.php?searchid=19631.
Dave
