433Mhz Transmitter/Receiver Problems! Help!
Hi Group,
I'm having problems with the 433Mhz transmitter and receivers from Parallax.· I'm getting all kinds of interference.
My program just sends numbers over from 0 to XXXXX· and the receiver just gets that data and displays it on the debug terminal (attached via the USB CABLE).
Problems I am having:·
1) Even when the transmitting BS2 is powered· off, the receiver is still getting random data, (continuous data). I tried putting a resistor between Pin7 & data, and this still didn't help
2) I'm just broadcasting numbers from 0 to whatever, and incrementing by 1.· However , sometime after 100, it starts incrementing by 2!!! Even the code only says x = x + 1 and y = y +1
Please help.
The code is listed below:
TRANSMIT CODE
x var Word
y var Word
DO
pulsout 8, 1200
SEROUT 8,16468, [noparse][[/noparse] "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
x = x + 1
y = y + 1
pause 10
LOOP
Receive Code
x· var Word
y var Word
DO
LOW 0
SERIN 7, 16468, [noparse][[/noparse]WAIT("!"), x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
HIGH 0
DEBUG ? x
DEBUG ? y
LOOP
Post Edited (rfman78) : 7/17/2007 6:13:52 PM GMT
Please help.
TRANSMIT CODE
x var Word
y var Word
DO
pulsout 8, 1200
x = x + 1
y = y + 1
pause 10
LOOP
Receive Code
x· var Word
y var Word
DO
LOW 0
HIGH 0
DEBUG ? x
DEBUG ? y
LOOP
OS-X: because making Unix user-friendly was easier than debugging Windows
links:
My band's website
Our album on the iTunes Music Store
I forgot to show the pause 10 command, which i do have. And as I said, it works fine , until about 101, 102 at which point it starts incrementing by two.
For the interference, it only happens when the USB Cable is plugged into the computer. But thats the only way I can monitor the Debug statements......
2) Like most "unlicensed" radio bands, the 433MHz band is shared with other devices like garage door openers and wireless burglar alarms.
That might be one source of noise when the transmitter is off.
links:
My band's website
The problem only rears its head when the USB cable is plugged in.· Is there any way that cable or the laptop could be causing that random interference, and is there anyway I can get around that? Ie some kind of small filter circuit I can build in the· dev. board?
Here: www.radioshack.com/product/index.jsp?productId=2103979&cp=2032058.2032230.2032273&parentPage=family
Post Edited (Mike Green) : 7/17/2007 6:28:46 PM GMT
use a .1 uf cap from stamp to Rf unit, I found the rf unit I was using held about .25 to .5 volts high when not sending.
depending on the mode of transmission use a resistor from rf unit to ground or +5 this holds the rf unit high or low depending on mode and does not allow floating.
