I need a circuit that will sense the hall effect magnet
I am total newb to the basic stamp, and designing circuits.
I have a project I need to get done fast (really fast) and don't really have the time to learn everything to make it work right.
I will be experimenting and learning later but for now it just has to get done ASAP...
Its a pretty basic thing. I am good at building, so I just need a circuit that will work and hopefully some code suggestions.
Heres what I need.
I have hall effect sensor and magnets from parallax.
I need a circuit that will sense the hall effect magnet when it passes by the sensor and will simply activate a solid state relay for a defined amount of time each magnet passes the sensor.
It shouldn't effect the circuit, but to give an idea I have 30 magnets positioned on a rotating disc. I need it to signal the relay so it can fire a strobe at precisely the point the magnet is in front of the sensor (where someone will be viewing the animation). This is so it can freeze the motion of the rotating disc.
Yoshi
Post Edited By Moderator (Chris Savage (Parallax)) : 7/17/2007 2:38:47 AM GMT
Heres what I need.
Yoshi
· Anyway, the Hall sensor output could provide the trigger·to "one-shot" (based on a 74HC123 or 74HC221) and the one-shot output could trigger your "strobe."
· Was it your intention to use a Stamp?· Maybe this should have been posted over in The Sandbox.
Because I might need to build in a delay which I could control with the stamp.
You could use PULSOUT in the "strobe" sub-routine instead of OUT.· Any more than this from me and we're looking at design fees, N-R-E, etc.·
