Alternative PC Kybd & Mouse hardware
Hi All,
Does anyone know if its possible to get PS2 keybd & mouse compatible hardware? e.g. :
1 : A bunch of ( perhaps panel mounted) momentary push switches that when pressed send PS2 kybd presses.
2 : An X/Y controller, or other controller that would send the appropriate mouse XY over PS2.
I think that with the bonus of having kybd/mouse drivers for the prop, this would be useful where kybd commands & mouse movement are used for control, but when I want to be able to build a custom design. i.e. I dont have to use a standard kybd and mouse (which I hate! because gives me such a shoulder pain!)
cheers
Dave
cheers
Dave
Post Edited (deSilva) : 7/15/2007 1:40:58 PM GMT
2) Mice with balls have optical encoders, it would not take much effort to remove them and wire up other encoders or a pulse generator circuit controlled by a potentiometer joystick.
Or you could go full custom. I don't unfortunately know of any convenient PS/2 driver chips to make it super simple.
Graham
In answer to your question, sure it's possible. In fact, I'm surprised I haven't seen an object to do this yet. I did something similar years ago using a PIC, that would send PS2 keyboard codes. Based on that experience, I know that the Propeller is fully capable of doing the same. There are a few objects that go the other way around and read a Keyboard or Mouse, so I know all of the information is there.
Beau Schwabe
IC Layout Engineer
OBJ
text : "tv_text"
VAR
long key,row,col
PUB start | i
text.out($00)
text.start(12) 'start terminal
text.str(string($A,1,$B,1))
repeat
getkey
text.hex(key,1)
pub getkey
dira[noparse][[/noparse]23..20]~~ 'output columns
dira[noparse][[/noparse]19..16]~ 'input rows
col :=1
repeat
outa [noparse][[/noparse]23..20] := !col 'pull one column low at a time
row := ina[noparse][[/noparse]19..16]
if row <> $f 'if low row, look at $colrow
key := lookdown(ina[noparse][[/noparse]23..16]: $ee,$de,$be,$ed,$dd,$bd,$eb,$db,$bb,$7e,$7d,$7b,$77,$e7,$b7)
waitcnt (10_000_000+cnt)
waitpeq ($f0000,$f0000,0) 'wait key release
quit
col := col*2 'col = 1,2,4,8
if col >8
col := 1
http://www.billbuxton.com/InputSources.html
from which I found this place
http://www.electroneamericas.com
which has pretty much exactly what I want. They do modular keyboards in 8x8 and other layouts. Normal (cheap) and industrial (very expensive!)
Still looking down Bill's extensive list...
cheers
Dave
I wrote a minimal quick prog to output the symbol / hex code to my vga display. Enclosed below...
cheers
Dave
