Parallax GPS module and heat
I have·the Parallax GPS module and am planning on mounting it inside my car in the back wondow. It will be inside the plastic rear window center brake light housing.·It has been in the high 90's temperature over the last couple of weeks and·I am worried about frying the unit from the heat. I've heard the temp inside a car in the hot sun can be as high as 135 degrees with the windows rolled up. Can anyone tell me if that will fry the GPS unit or not?
I suppose as long as·I don't open the plastic housing and let the smoke out, I should be OK.·
I don’t have any temperature ratings for the Polstar Module, you could check the datasheet. Most often circuits like that are at least rated commercial (0C-70C). Inside the third tail light assembly aren’t you going to also be subject to heat from the bulbs in there? Take care.
Chris Savage
Parallax Tech Support
DARPA Urban Challenge here I come.
Yah right. Maybe when I secure $1 million in seed money.
HTH, Chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
