How to connect the Ping to a BS2 Homework board?
I have read some on the forum about the connection of the Ping on the BOE and problems adjusting the code to avoid get·situations on the readings due phantom echoes·and thing like... I read the fact that the power consumption is a important detail to check, so I have the question of how to connect the Ping to the Homework Board? I will use a pack of batteries to power it and be sure it·have power·to run fine?
Post Edited By Moderator (Chris Savage (Parallax)) : 7/11/2007 12:18:23 AM GMT
I'm just guessing that i should connect it on the same way than the servos, the battery pack (6 volts) positive to the Vcc and the negative to the Vss and then to GND on the module...?
The·specification data say the minimun Vcc is 4.5 volts and the max is 5.5 volts, do I need a resistor between the positive from the battery pack and the Vcc input on the Module?
Post Edited By Moderator (Chris Savage (Parallax)) : 7/11/2007 12:16:43 AM GMT
http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
http://www.parallax.com/dl/docs/prod/audiovis/EmicModules.pdf
Chris Savage
Parallax Tech Support
Do you think I can power bouth at the same time, or well not at the same time, but for example make the Emic speach the values thet the ping read?
Mr Fus
http://microbots.mx.tripod.com/
Panama City Beach, FL
What I want to do is to have the 2 homework boards connected between and use the one that is Rev B to control the servos and some sensors (contact ones and a couple of QTI Sensors) <!-- unit price -->and the one that is Rev C to get the PING, IR remote and the EMIC (if i can run all at the same time on a coordinated way·
Well one step at the time... I have already understand on a partial way how the·connection between the boards work, and I have made some·work on that, now I will start working on the PING and IR control and then on the EMIC.
Mr Fus
Mr Fus
Post Edited (Mike Green) : 7/12/2007 5:29:09 AM GMT
Mr Fus
It is always recommended to review fully the documentation and example source code before posting questions covered by these. If the information is in the documentation or example code that is the response you’re going to get first. It would save some posting if you did this first. Take care.
Chris Savage
can I use a circuit of a DC to DC regulator to power the EMIC on a independent way from the Homework Board?
(This is Circuit diagram of the power supply, I m thinking to use a 9 volts battery pack to power it...)
Mr Fus
