Capacitor question
Hi,
I'm working on a project where I've got a stand-alone instrument that puts out a TTL word that I want to multiplex into 16 discrete DO lines. I've got the multiplexer working, but I'm worried about my instrument sending the 'word' too slow and getting a false signal to one of the other 15 lines as the word builds.
I have the option of using an additional line as a latch, but that would complicate my life greatly. (plus I really don't want to lose one of my lines for this)
I'm using the TTL DO to trigger a relay that then does the task. What I'd like to do is build a delay into the circuit so that any chatter is eliminated while the 'word' out signal stabilizes. I have some timer relays that would work, but I was wondering if there was a better (cheaper, simpler) way to accomplish the same thing with a capacitor.
Just something that waits 50msecs would be plenty.
Does anyone have any suggestions or recommendation as to where I can get some more info?
Lance
Lance
a scheme is worth more than thousand words.
Ed
I have a question though...How do I calculate the delay?
My stamps manual says t=RC. Do I understand this correctly to be the time it takes to charge the capacitor and then trigger the relay?
For testing I'm using an LED as my "relay" and my 'series' resistor is 470 ohm. I figure it will be easier to control the timer with the capacitor as well as protecting the LED.
So if I have a 470 ohm resistor and a 3300 microF capacitor that would give me a t=1.551
Is that the delay?
From observation it takes about a second for the LED to reach full intensity, but it seems to light up almost immediately.
Lance
I'll have to do some research and find the datasheet for the relay in question.
Lance
