Operational Temperature Range of Propeller Chips?
What is the Operational Temperature Range of Propeller Chips? (Commercial, Industrial, Military?)
I am considering using one for Weather Measurements and it may get as cold as -60* F or so.
Thanks!
Thanks!
Paul Baker
That one sample had no problem whatsoever with the transitions. The brownout detector and the oscillator and clock chain are analog blocks and are the most likely to have problems at temperature extremes. Chip assured us at the beta testers' meeting that considerable care was taken in the design of those circuits and left plenty of margin calculated for extremes of temperature. That is in line with what he just said in the manifesto about "why it works..."
Tracy Allen
www.emesystems.com
Thanks for doing that test. Is -65 the limit of your chamber?
Chip Gracey
I take it that this proposed weather app. is going to be battery powered ? That will be a big consideration if it is the case as you are probably aware battery performance will be seriously diminished in extremes of cold. Its not just the prop for consideration here - at this temp. I would seriously consider a heat pump - If you plan to use adc's with a reference device - I have seen temps. affect the voltage reference components - thus affect accuracy of measurement..
It is true that other components in the system, the reference electronics or the battery or the packaging, can be critical in temperature extremes, and condensation on circuit boards can affect both accuracy and longevity.
A couple of weeks ago we were recording -22 Celsius at Crane Flat in Yosemite. It rarely gets that low here in California. At those temperatures the sealed PbAcid batteries are near their low limit, although the systems do have a temperature compensated float charger and the batteries have lots of reserve capacity. For really low temperatures the Lithium chemistries are better.
Tracy Allen
www.emesystems.com
The Propeller is way over-kill for this project, but I'm using it anyway. Right now I'm working on the Transmitter; last time it was out of range at about at about 40 miles or so - I need about three to four times that distance. I have a little 80 Meter Transmitter knocking out Morse Code, but haven't tested it for distance yet.
Is there any thought to testing the propeller over mil specs?· I work with Fiber Optic Gyros and such and it would be nice to tell this to my customers.
Greg
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
In regards to the hot vs. cold being the critcal factor, it all depends on the chip. Frequently it is the hotter temperatures that cause a chip to fail a fitness test, but this isn't always the case.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 3/27/2007 2:00:47 PM GMT
http://www.centerofengineering.com
Ken Peterson
If condensation is a problem with systems out in the weather, you might want to try this as a coating.
I've been toying with using the Propeller for some things to do with SCUBA Diving. If anyone is interested, I'll coat a couple of boards and see how they survive a dunk in salt water. I'd also be interested in seeing what happens to these boards at the extremes of temperature as well.
" Anything worth doing... is worth overdoing. "
··············································· ( R.A.H. )
Thanks for the offer, we have an environmental chamber. We are just waiting for an electrician to rewire the 120V 20A dedicated outlet (should be any day now).
Paul Baker
