Program and debug sx28 @ low voltage (2 - 3.3 V)
Hello,
What about SX Key Ring - Stock code #45211 that is in the SXBrochure2006.pdf ?
Is possible to program and debug an "in-circuit" application that need a supply voltage of 2 - 3.3 V with sxkey tool?
I don't see the SX Key Ring in PARALLAX product section, Is there any other tool to do this?
Thank You
MarcoP
Thank You
MarcoP
If you have a 5 volt power supply it wouldn't take much to make a little adapter.
At 3.3V you would be okay. I don't know about 2 volts though...
Bean.
Never argue with an idiot.· They'll drag you down to their level then beat you with experience.
www.hittconsulting.com
