Accessing parameters in a VAR block as longs — Parallax Forums
ciphernetciphernet Posts: 24
edited 2007-07-10 22:09 in Propeller 1
Hi all,
Get a bit of trouble getting this code to work... What am I doing wrong???
I defined a DAT block with LONG values (approx 300 longs) and I get a constant error message: "Size overwrite must be smaller"
(Motor and mot·are defined·as LONG vars in the var section of my SPIN program)
In SPIN:
Motor:=MOTOR_MODE_VALUES.LONG[noparse][[/noparse]mot]
DAT
MOTOR_MODE_VALUES
·LONG·· 0095,0195,0295
·LONG·· 0395,0495,0595
·LONG·· 0695,0795,0895
·etc..
Jan
·Give me some slack, please.. I have programmed SX controllers for five years but the prop just blows my mind :-)
    edited 2007-07-07 22:48
    MOTOR_MODE_VALUES is already LONG since that's the declaration you're using. I'm not sure why you're getting the message other than that you don't need it. Just use Motor := MOTOR_MODE_VALUES[noparse][[/noparse]mot]
  • ciphernetciphernet Posts: 24
    edited 2007-07-07 22:53
    Hi Mike,
    I have tried that and I am checking the result on my Scopemeter. It seems like nothing happens, but I will have to check my code again. At least I get no error messages anymore.
    Thanks for your reply. Your knowledge·about the prop is amazing.. :-)
    Jan
  • KaioKaio Posts: 280
    edited 2007-07-09 13:50
    Following code should work properly.
      Motor:=LONG[noparse][[/noparse]@MOTOR_MODE_VALUES][noparse][[/noparse]mot]
    The code you was using implies that the variable is an array. But it is declared in DAT section, so you can only access it as address.
    Thomas
    Post Edited (Kaio) : 7/9/2007 1:57:24 PM GMT
    Thanks Thomas, That works
    Jan
