PSC trouble
Hello,
I can not make my PSC work with my BOE (with BS2p24). The PSC works correctly with USB and is identified as firmware version 1.4. Initially, I pasted the attached code from the PSC example and have changed the timeout and added DEBUG lines. What am I doing wrong here?
The green LED on the PSC blinks when the program is running; stops when the reset button on the BOE is held down. What does this indicate about the PSC?
Any help would be appreciated.
I believe that the value for·your Baud constant for 2400 baud, in your Problem.txt file, is incorrect.
Your value of 396 is for a BS2 and not a BS2p.
The value for 2400 baud for a BS2p is 1021.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
You are correct.
Thank you.
Tyfume
