HELP! DS1307 issues [s](again)[/s] (still) — Parallax Forums
Chuck E.Chuck E. Posts: 14
edited 2007-07-12 21:00 in BASIC Stamp
Hi gang,
I'm still learning, even if slowly. I'm having trouble setting my RTC on the Professional Development Board. Maybe some of you gurus can point out my error, I'm sure it'll be something obvious.
SDA is on 0, SCL on 1.
Here is what I did:
' {$STAMP BS2p}
DS1307 CON %1101 << 4
sec VAR Byte
minute VAR Byte
hour VAR Byte
day VAR Byte
date VAR Byte
month VAR Byte
year VAR Byte
'I2COUT 0, ds1307, 1, [noparse][[/noparse]DEC 20]
'I2COUT 0, ds1307, 2, [noparse][[/noparse]HEX 10]
'I2COUT 0, ds1307, 3, [noparse][[/noparse]DEC 05]
'I2COUT 0, ds1307, 4, [noparse][[/noparse]DEC 06]
'I2COUT 0, ds1307, 5, [noparse][[/noparse]DEC 07]
'I2COUT 0, ds1307, 6, [noparse][[/noparse]DEC 07]
main
I2CIN 0, DS1307, 1, [noparse][[/noparse]minute]
I2CIN 0, DS1307, 2, [noparse][[/noparse]hour]
I2CIN 0, DS1307, 3, [noparse][[/noparse]day]
I2CIN 0, DS1307, 4, [noparse][[/noparse]date]
I2CIN 0, DS1307, 5, [noparse][[/noparse]month]
I2CIN 0, DS1307, 6, [noparse][[/noparse]year]
DEBUG HEX sec, " seconds", CR
DEBUG HEX minute, " minutes", CR
DEBUG HEX hour, " hour", CR
DEBUG HEX day, " day", CR
DEBUG HEX date, " date", CR
DEBUG HEX month, " month", CR
DEBUG HEX year, " year", CR
PAUSE 100
DEBUG CLS
GOTO main
I borrowed this part: "DS1307 CON %1101 << 4" from a clock program from Stampworks, damfino if it's right, this might be part of the problem ¿Quíen sabe?
When I ran it the first time, it was at 10:20 this morning without the I2COUT statements commented out. I neglected to write down the output of the debug window, but it wasn't what I was expecting. I've since run it some more with the I2COUT stuff commented out, and what I got just a few minutes ago was:
0 seconds
88 minutes
65 hour
54 date
23 month
55 year
So fellas and fellowettes, what obvious thing am I missing/screwing up?
Chuck
Oh, yeah, RTC battery is installed, and I clear the stamp memory between running programs.
Post Edited (Chuck E.) : 7/6/2007 4:01:09 PM GMT
    edited 2007-07-06 16:00
    Chuck,
    Use HEX in all the I2Cout commands, not DEC.
    Tracy Allen
    www.emesystems.com
    edited 2007-07-06 16:56
    You could also check the thread right below which has a link to both the documentation and source code for DS1307 experiments.
    http://forums.parallax.com/showthread.php?p=660091
    Chris Savage
    Parallax Tech Support
  • Chuck E.Chuck E. Posts: 14
    edited 2007-07-06 18:01
    Terry, you hit the nail on the head, thanks!
    Changed this:
    To this:
    'I2COUT 0, ds1307, 1, [noparse][[/noparse]$20]
    And all was right with the world.
    The link Chris points to is where I got most info needed, also the 1307 datasheet is a help for address info on the registers. I did learn something from all this, so it's not a total loss.
    Chuck
    So boyz -n- gurlz, would it work the same if I used BCD?
    CE
    edited 2007-07-06 18:04
    By using $20, you're effectively using BCD which represents two digits in 8 bits (two hex digits).
    Just in case anybody wants a ready-made solution for setting or checking their DS1307 RTC and are using BS2P. (I2C bus commands I'm using aren't in other BS2 command sets) I've been running this since last week and no bugs or other problems so far. I hope somebody finds this useful. Here is the program:
    ' {$STAMP BS2p}
    ' DEBUG "Stamp clear."
    ' File created by Chuck E.
    sec VAR Byte
    minute VAR Byte
    hour VAR Byte
    day VAR Nib
    date VAR Byte
    month VAR Byte
    year VAR Byte
    'Set I2COUT variables between the [noparse]/noparse to correct values just before running.
    'Comment out with "'" at beginning of command line any that do not need to be
    'updated. Comment out all I2COUT lines if you only want to see RTC time.
    'Day: Sunday = 0, Monday = 1, Tuesday = 2, etc.
    'I2COUT 0, ds1307, 1, [noparse][[/noparse]$41]
    'I2COUT 0, ds1307, 2, [noparse][[/noparse]$08]
    'I2COUT 0, ds1307, 3, [noparse][[/noparse]$03]
    'I2COUT 0, ds1307, 4, [noparse][[/noparse]$11]
    'I2COUT 0, ds1307, 5, [noparse][[/noparse]$07]
    'I2COUT 0, ds1307, 6, [noparse][[/noparse]$07]
    I2COUT 0, ds1307, 7, [noparse][[/noparse]$10] 'this line enables 1Hz output
    'I2COUT 0, ds1307, 7, [noparse][[/noparse]$00] 'this line disables 1Hz output
    main
    I2CIN 0, DS1307, 0, [noparse][[/noparse]sec] 'gets seconds from RTC
    I2CIN 0, DS1307, 1, [noparse][[/noparse]minute] 'gets minutes from RTC
    I2CIN 0, DS1307, 2, [noparse][[/noparse]hour] 'gets hours from RTC
    I2CIN 0, DS1307, 3, [noparse][[/noparse]day] 'gets day of week from RTC
    I2CIN 0, DS1307, 4, [noparse][[/noparse]date] 'gets date from RTC
    I2CIN 0, DS1307, 5, [noparse][[/noparse]month] 'gets month from RTC
    I2CIN 0, DS1307, 6, [noparse][[/noparse]year] 'gets year from RTC
    DEBUG HEX sec, "seconds", CR 'displays seconds in debug window
    DEBUG HEX minute, "minutes", CR 'displays minutes in debug window
    DEBUG HEX hour, "hour", CR 'displays hours in debug window
    DEBUG HEX day, "day", CR 'displays day of week in debug window
    DEBUG HEX date, "date", CR 'displays date in debug window
    DEBUG HEX month, "month", CR 'displays month in debug window
    DEBUG HEX year, "year", CR 'displays year in debug window
    PAUSE 250 'delay between refreshes
    DEBUG CLS, "RTC Clock Repeater", CR
    GOTO main
    Chuck
