another assembly question
I'm having trouble executing code in assembly based on whether a variable is less than 0. can anyone explain to me
how this be written in assembly:
if variable < 0
execute code
sorry if this is too basic but I wasn't able to understand how to do this from the manual.
Owen
if variable < 0
execute code
Owen
cmps variable,#0 wc if_nc jmp #:skipIt ' Here's the code to be executed :skipItcmp t2,t3 wc
if_c jmp #
' rest of code (negative part) goes here
The trick, as I have understood it, is to remember to write the right flag - and then check it.
Anyhow, you got it from Mike. Trust him.
