Irrigation / sprinkler valve
I would like to control a standard irrigation valve from a microprocessor. Has anyone ever controlled an irrigation valve? I think that they are 12v devices, and are bipolar. This leads me to believe that a standard h-bridge should do the trick.
Any suggestions for easy to find h-bridges or good transistors and circuits for making my own are appreciated.
Thanks!
- narced
Thanks!
- narced
- Stephen
Post Edited (Philip Gamblin) : 7/1/2007 4:51:46 PM GMT
I've run both Orbit and Toro models on 18v DC from a Ryibi portable drill, and I've heard of Pneumatic spud guns that were triggered with two 9v cans batteries in series.
Never tried thatmyself, though.
Running them on DC makes triggering easy- just use a TIP 120 or a FET.
here's a system thats rated as DC www.mrdrip.com/timer540000.htm
- narced
Skylight, As far as magnetizing the cores, I haven't had that problem. I suppose you could if you have a higher duty cycle than I've used, But I don't know. You might just try reversing the leads periodically. What kind of time span and use are you talking about? If it was over a few years, it still might be cheaper to rplace a solenoid occasionally than buy a bank of h-bridges. I've had to replace one 'cause it cracked form age or frost.
Philip, How can you tell the solenoids are any different? I've bought valves at HD with manual shutoffs (turn on, actually, remove the mechanism and they stay shut), if that's what you want. It was a few years ago, though. You might have to buy manual valves and a solenoid conversion kit.
The one that i used are the Toro solenoid
You can run these valves on DC current
I·found·the solenoid ran at 7.5 volts DC·@ 230 milamps
The problem that i saw was that the current went up as·I put more voltage solenoid and was getting some what warm
so i just ran them on my power supply· at 7.5 volts DC
·I just put in my sprinker system and this is how i tested·each zones that i was putting in with the power supply before I hook up the controler
that i bought
I hope this helps you in what you want to do
I would run them on AC current and a soild state relay·I think it would be easyer to it that way
··Thanks for any·
Sam
Shawn Lowe
My last words shall be - "NOT YET!!!"
Why not? it's just an electromagnet. I think the original surprise for Edison was that you could run such things on AC.
There are all sorts of devices that will run fine on DC. some examples--light bulbs, pumps, and power tools(I'm talking the kind you plug in).
When I was in college in the 60's, I once rented a farmhouse from a farmer who used DC current off a tractor to run Skil saws and power drills when he was out about his property. Inverters were pretty expensive, then.
When I asked him about it, he laughed and said that until about 20 years before that, all the local service from the farmer's coop was DC and most stuff ran fine. I'm not sure that's the case, anymore. I wouldn't try doing that with a microwave.
Actually, there is one reason not to use DC I've heard from someone who installs irrigation systems--apparently with underground cables, there's a greater chance that current leakage could cause galvanic damage to wires or nearby burried metal objects, especially galvanized pipes. I know that was a problem with Old electric trolley systems if the track continuity was poor.
Great! Thanks for all the input guys.
- jason
