Why is this code not working? (Weather Vane)
' {$STAMP BS2e}
' {$PBASIC 2.5}
_INIT CON $FFAA 'INITIALIZE COPROCESSOR
_ERRORS CON $FE 'Get Error Flags
_LOW CON $B0 'SET PIN OUTPUT LOW
_HIGH CON $B1 'SET PIN OUTPUT HIGH
_INPUT CON $B2 'SET PIN TO INPUT
_INPUTP CON $B6 'SET PIN TO INPUT WITH PULLUP
_PUSH CON $D0 'PUSH ONE BYTE ON STACK at the current sram pointer and increment pointer
_POP CON $D1 'decrement sram pointer and POP ONE BYTE OFF STACK
_ZSTACK CON $D2 'ZERO THE STACK POINTER
_CLRBL CON $B7 'CLEAR THE BLATCH REGISTER
_CLRCL CON $B8 'CLEAR THE CLATCH REGISTER
_RPINSA CON $C0 'READ PINS 0...5
_RPINSB CON $C1 'READ PINS 6..11
_RPINSC CON $C2 'READ PINS 12..18
_PINSBL CON $C3 'READ LATCHED LOW PINS 6..11
_PINSCL CON $C4 'READ LATCHED HIGH PINS 12..18
_SECONDS CON $C5 'Read seconds
_MINUTES CON $C6 'Read Minutes
_HOURS CON $C7 'Read Hours
_TIME CON $C8 'Read seconds,minutes,hours
_ADC0 CON $A0 'READ ADC0
_ADC1 CON $A1 'READ ADC1
_ADC2 CON $A2 'READ ADC2
_ADC3 CON $A3 'READ ADC3
_ADC4 CON $A4 'READ ADC4
_ADC5 CON $A5
_WRITEFLASH CON $D3 'write 5120 bytes from SRAM to FLASH memory
_READFLASH CON $D4 'Read 5120 bytes from FLASH to SRAM memory
_Readsram CON $D5 'Read a byte at the current sram pointer and increment pointer
_setstack CON $D6 'Set the Sram pointer
_EWRITE CON $D7 'wRITE A BYTE TO EEPROM
_EREAD CON $D8 'Read a byte from EEPROM
vane1 VAR Word
vane2 VAR Word
page VAR Byte
TEMP VAR Word
BUFFER VAR Byte
Seconds VAR Byte
Minutes VAR Byte
Hours VAR Byte
adcval0 VAR Word
adcval1 VAR Word
delta VAR Word
bearing VAR Word
ad1 VAR Byte
ad0 VAR Byte
x VAR Byte
DEBUG "CO-PRO-M48 WeatherVane Test Program",CR
PAUSE 1000
delta = 700 'delta is the overlap between wipers
readvane:
GOSUB adc
DEBUG DEC adcval0,",",DEC adcval1,",",DEC bearing,CR
[color=red]'CODE FROM FANTASTICELECTRONICS.com weather vane kit
' Decide IF we should update the delta value.
IF adcval0 > 5120 - 2 * delta AND adcval0 < 4920 AND adcval1 < 2 * delta AND adcval1 > 200 THEN
delta = (9 * delta + (adcval1 + 5120 - adcval0) / 2) / 10
ELSEIF adcval1 > 5120 - 2 * delta AND adcval1 < 4920 AND adcval0 < 2 * delta AND adcval0 > 200 THEN
delta = (9 * delta + (adcval0 + 5120 - adcval1) / 2) / 10
ENDIF[/color]
[color=red]' Decide IF we have a valid bearing off of one of the wipers.
IF (adcval0 > delta AND adcval0 < 5120 - delta) AND (adcval1 > 5120 - delta OR adcval1 < delta) THEN
bearing = 180 * (adcval0 - delta) / (5120 - 2 * delta)
ELSEIF (adcval1 > delta AND adcval1 < 5120 - delta) AND (adcval0 > 5120 - delta OR adcval0 < delta) THEN
bearing = 180 + 180 * (adcval1 - delta) / (5120 - 2 * delta)
ENDIF
[/color]PAUSE 5000
GOTO readvane
adc:
adcval0 = 0
adcval1 = 0
SHIFTOUT 0,1,1,[noparse][[/noparse]_ADC0]
SHIFTIN 0,1,0,[noparse][[/noparse]adcval0]
adcval0 = adcval0 * 20
PAUSE 100
SHIFTOUT 0,1,1,[noparse][[/noparse]_ADC1]
SHIFTIN 0,1,0,[noparse][[/noparse]adcval1]
adcval1 = adcval1 * 20
RETURN
Can someone look at the highlighted code and tell me why it is not resolving bearing and why it never changes delta. the values for adcval range from about 20 to 5100.
If you need more info just ask, Thanks
- Stephen
needs some Parentheses worked in (as similar lines have.)
Tracy Allen
www.emesystems.com
- Stephen
